Cisco 7961 Help -->SIP newbee here! please help
Hi all i just got a 7961 from my company, there are getting new model so i asked for 1 so i can start learning on this... i'm trying to set this phone so i can get it conected to my VoIP server. i'm been doing some search but with out any luck... well not that much.. i was able to creat my on TFTP and i was able to change the firmware... i use to have:
loadfile: sccp41.8-2-1s
bootload id: 7961g_64-02070631AMD64megRel.bin
and i change it to:
loadfile: term61.defaul
bootlad id: same
so i don't know if i'm doing it the right way.. i know that now i have SIP configuration.. but i can edit it at all... all i get is the msg "Unprovisioned" all i'm trying to do is to be able configure my sip information...
i'm running or pointing my tfpt to a floder called cmterm-7941_7961-sip.8-3-1 it has 8 files on it...
Can some one help me or point me to a place where i can get more info.. i'm stuck in here...
Thanks in advances!
Everyone's tags (3)
I forgot to mention i'm trying to use it a stand alone phone...
Hall of Fame Super Silver
What is your VoIP server?
Chris
Hi and thanks for replying! My server is a Online company: voip.ms
Anyone available to help me out??
I haven't done what you are asking but the firmware you list isn't recognizable to me. Of course, it the right firmware was renamed then that could explain it. Anyway, you may want to verify you have the right firmware.
Cisco has a detailed guide on converting a 7960:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Also, the voip.ms wiki has UA configuration information.
http://wiki.voip.ms/article/Cisco_IP_Phone_7940/7960
I didn't find similar docs (with the same level of detail, that is) for the 7961. However, the basic concepts are the same but the interface (i.e. menu structure) is different.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hi All I finally manage to get a smartnet contract. i was able to upgrade my 7961G firmware, now i have 9.3 sip version on it.. i was able to "configure the sep.cnf.xml file with my VOIP server information but the phone is not registering at all... is there anything suggestion???
Hall of Fame Super Gold
For using Cisco phones with third-party servers, you will find more information on sites like voip-info.org than here.
Otherwise if you want sure and quick results, get a phone from the small business like, Linksys, etc.
1707
