Community Member
Cisco 7961 Phones Incoming call cutting out
Hello, I really need your help.  We have 10 7961 ip phones.  Below is the Topology.  Basically we have the PSTN network with 8 Analog lines going to 2 VIC 2 and 4 FXO cards into the Voice gateway 2901 series.  Then we have the CUCM in another location and than a Catalyst switch, then the phones.  The incoming phone calls are cutting out.  Speed and Duplex settins on the Swithes are Set to auto Negotiate.  Each Port on the Voice Vlan are also on the Data vlan.  The ports were set up with switchport mode Voice vlan# command.
PSTN—(8 Analog Lines –to- 2x VIC2-4FXO)—GW—(h323)—CUCM—(sccp)—IP Phones
This issue is intermittent.  The incoming calls keep cutting out.  Can anyone help, it will be greatly appreciated.
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxo-ls      up    dorm idle     on-hook  y
0/0/1           --  fxo-ls      up    dorm idle     on-hook  y
0/0/2           --  fxo-ls      up    dorm idle     on-hook  y
0/0/3           --  fxo-ls      up    dorm idle     on-hook  y
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/1          2      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/2          2      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/3          2      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/4          2      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/5          2      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
50/0/6          2      efxs     up    up   on-hook  idle     y
50/0/7          1      efxs     up    up   on-hook  idle     y
50/0/7          2      efxs     up    up   on-hook  idle     y
50/0/8          1      efxs     up    up   on-hook  idle     y
50/0/8          2      efxs     up    up   on-hook  idle     y
50/0/9          1      efxs     up    up   on-hook  idle     y
50/0/9          2      efxs     up    up   on-hook  idle     y
50/0/10         1      efxs     up    up   on-hook  idle     y
50/0/10         2      efxs     up    up   on-hook  idle     y
50/0/11         1      efxs     up    up   on-hook  idle     y
50/0/11         2      efxs     up    up   on-hook  idle     y
50/0/12         1      efxs     up    up   on-hook  idle     y
50/0/12         2      efxs     up    up   on-hook  idle     y
50/0/13         1      efxs     up    up   on-hook  idle     y
50/0/13         2      efxs     up    up   on-hook  idle     y
50/0/14         1      efxs     up    up   on-hook  idle     y
50/0/14         2      efxs     up    up   on-hook  idle     y
50/0/15         1      efxs     up    up   on-hook  idle     y
50/0/15         2      efxs     up    up   on-hook  idle     y
50/0/16         1      efxs     up    up   on-hook  idle     y
50/0/16         2      efxs     up    up   on-hook  idle     y
50/0/17         1      efxs     up    up   on-hook  idle     y
50/0/17         2      efxs     up    up   on-hook  idle     y
50/0/18         1      efxs     up    up   on-hook  idle     y
50/0/18         2      efxs     up    up   on-hook  idle     y
50/0/19         1      efxs     up    up   on-hook  idle     y
50/0/19         2      efxs     up    up   on-hook  idle     y
50/0/20         1      efxs     up    up   on-hook  idle     y
50/0/20         2      efxs     up    up   on-hook  idle     y
50/0/21         1      efxs     up    up   on-hook  idle     y
50/0/21         2      efxs     up    up   on-hook  idle     y
50/0/22         1      efxs     up    up   on-hook  idle     y
50/0/22         2      efxs     up    up   on-hook  idle     y
50/0/23         1      efxs     up    up   on-hook  idle     y
50/0/23         2      efxs     up    up   on-hook  idle     y
50/0/24         1      efxs     up    up   on-hook  idle     y
50/0/24         2      efxs     up    up   on-hook  idle     y
50/0/25         1      efxs     up    up   on-hook  idle     y
50/0/25         2      efxs     up    up   on-hook  idle     y
50/0/26         1      efxs     up    up   on-hook  idle     y
50/0/26         2      efxs     up    up   on-hook  idle     y
50/0/27         1      efxs     up    up   on-hook  idle     y
50/0/27         2      efxs     up    up   on-hook  idle     y
50/0/28         1      efxs     up    up   on-hook  idle     y
50/0/28         2      efxs     up    up   on-hook  idle     y
50/0/29         1      efxs     up    up   on-hook  idle     y
50/0/29         2      efxs     up    up   on-hook  idle     y
50/0/30         1      efxs     up    up   on-hook  idle     y
50/0/30         2      efxs     up    up   on-hook  idle     y
50/0/31         1      efxs     up    up   on-hook  idle     y
50/0/31         2      efxs     up    up   on-hook  idle     y
50/0/32         1      efxs     up    up   on-hook  idle     y
50/0/32         2      efxs     up    up   on-hook  idle     y
50/0/33         1      efxs     up    up   on-hook  idle     y
50/0/33         2      efxs     up    up   on-hook  idle     y
50/0/34         1      efxs     up    up   on-hook  idle     y
50/0/34         2      efxs     up    up   on-hook  idle     y
50/0/35         1      efxs     up    up   on-hook  idle     y
50/0/35         2      efxs     up    up   on-hook  idle     y
50/0/36         1      efxs     up    up   on-hook  idle     y
50/0/36         2      efxs     up    up   on-hook  idle     y
50/0/37         1      efxs     up    up   on-hook  idle     y
50/0/37         2      efxs     up    up   on-hook  idle     y
50/0/38         1      efxs     up    up   on-hook  idle     y
50/0/38         2      efxs     up    up   on-hook  idle     y
50/0/39         1      efxs     up    up   on-hook  idle     y
50/0/39         2      efxs     up    up   on-hook  idle     y
50/0/40         1      efxs     up    up   on-hook  idle     y
50/0/40         2      efxs     up    up   on-hook  idle     y
50/0/41         1      efxs     up    up   on-hook  idle     y
50/0/41         2      efxs     up    up   on-hook  idle     y
50/0/42         1      efxs     up    up   on-hook  idle     y
50/0/42         2      efxs     up    up   on-hook  idle     y
50/0/43         1      efxs     up    up   on-hook  idle     y
50/0/43         2      efxs     up    up   on-hook  idle     y
50/0/44         1      efxs     up    up   on-hook  idle     y
50/0/44         2      efxs     up    up   on-hook  idle     y
50/0/45         1      efxs     up    up   on-hook  idle     y
50/0/45         2      efxs     up    up   on-hook  idle     y
50/0/46         1      efxs     up    up   on-hook  idle     y
50/0/46         2      efxs     up    up   on-hook  idle     y
50/0/47         1      efxs     up    up   on-hook  idle     y
50/0/47         2      efxs     up    up   on-hook  idle     y
50/0/48         1      efxs     up    up   on-hook  idle     y
50/0/48         2      efxs     up    up   on-hook  idle     y
50/0/49         1      efxs     up    up   on-hook  idle     y
50/0/49         2      efxs     up    up   on-hook  idle     y
50/0/50         1      efxs     up    up   on-hook  idle     y
50/0/50         2      efxs     up    up   on-hook  idle     y
VLAN Name                             Status    Ports
1    default                          active
21   VOICE_CWW                        active    Gi0/2, Gi0/7, Gi0/8, Gi0/9
                                                Gi0/10, Gi0/11, Gi0/12, Gi0/13
                                                Gi0/14, Gi0/15, Gi0/16, Gi0/17
                                                Gi0/18, Gi0/19, Gi0/20, Gi0/21
                                                Gi0/22, Gi0/23, Gi0/24, Gi0/25
                                                Gi0/26, Gi0/27, Gi0/28
40   DATA_CWW                         active    Gi0/1, Gi0/3, Gi0/4, Gi0/5
                                                Gi0/6, Gi0/7, Gi0/8, Gi0/9
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
392
