Community Member
Cisco 7961G IP Phone with Astrerisk Server Issue
I am having problem while connecting Cisco IP phone with Asterisk Server
Cisco 7961g IP Phone.
Version Using : SIP 41.9-2-3
Voip Server (Asterisk Server 1.6 Version)
192.168.0.135
I find so manythings but on wire shark also not coming any request.
Windows XP system :
192.168.0.195
Wireshark Log
3082    2028.725312    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
sip:Unknown@192.168.0.135
, in-dialog
3083    2028.726427    192.168.0.135    192.168.0.195    SIP    Status: 401 Unauthorized
3084    2028.827852    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
, in-dialog
3085    2028.828698    192.168.0.135    192.168.0.195    SIP    Status: 200 OK
1469    184.752685    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
, in-dialog
File <dialplan.xml> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:03:41.359]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:45:E8:A6:9C [23/07 11:11:41.875]
Previously allocated address 192.168.0.10 acked [23/07 11:11:41.875]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:45:E8:A6:9C [23/07 11:11:49.484]
Previously allocated address 192.168.0.10 acked [23/07 11:11:49.484]
Connection received from 192.168.0.10 on port 50657 [23/07 11:12:14.890]
Read request for file <CTLSEP001D45E8A69C.tlv>. Mode octet [23/07 11:12:14.890]
File <CTLSEP001D45E8A69C.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:14.890]
Connection received from 192.168.0.10 on port 50866 [23/07 11:12:15.015]
Read request for file <ITLSEP001D45E8A69C.tlv>. Mode octet [23/07 11:12:15.015]
File <ITLSEP001D45E8A69C.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:15.015]
Connection received from 192.168.0.10 on port 51212 [23/07 11:12:15.140]
Read request for file <ITLFile.tlv>. Mode octet [23/07 11:12:15.140]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:15.140]
Connection received from 192.168.0.10 on port 50804 [23/07 11:12:15.515]
Read request for file <SEP001D45E8A69C.cnf.xml>. Mode octet [23/07 11:12:15.515]
Using local port 2089 [23/07 11:12:15.515]
<SEP001D45E8A69C.cnf.xml>: sent 14 blks, 7120 bytes in 0 s. 0 blk resent [23/07 11:12:15.531]
Connection received from 192.168.0.10 on port 50713 [23/07 11:12:27.515]
Read request for file </mk-sip.jar>. Mode octet [23/07 11:12:27.515]
File <\mk-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:27.515]
Connection received from 192.168.0.10 on port 50382 [23/07 11:12:28.687]
Read request for file <US/g3-tones.xml>. Mode octet [23/07 11:12:28.687]
File <US\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [23/07 11:12:28.687]
Connection received from 192.168.0.10 on port 53157 [23/07 11:12:40.046]
Read request for file <dialplan.xml>. Mode octet [23/07 11:12:40.062]
File <dialplan.xml> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:40.062]
Everyone's tags (5)
1 REPLY
Blue
Cisco ip phone are not tested to run with third party application.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
535
