Cisco 7962 over VPN using ASA
Hello Everyone,
I am running into an issue with configuring 7962 connecting to Call Manager over VPN Connection. I get VPN Authentication Failed with "All Concentrators Failed" error in Status messages.. Please look at the following config on ASA:
crypto ca trustpoint VpnPhone
enrollment self
subject-name CN=Firewall
crl configure
crypto ca trustpoint CallManager.pem
enrollment terminal
crl configure
crypto ca trustpoint CAPF.pem
enrollment terminal
crl configure
crypto ca trustpoint Cisco_Manufacturing_CA.pem
tnrollment terminal
crl configure
I have uploaded certificates from ASA to Call Manager and from Call Manager to ASA.
ssl trust-point VpnPhone Outside
webvpn
enable Outside
anyconnect ....path to image file
anyconnect enable
tunnel-group-list enable
group-policy PhoneVPN internal
group-policy PhoneVPN attributes
vpn-tunnel-protocol ssl-client ssl-clientless
address-pools value VPN_Phone
tunnel-group VPNPhone type remote-access
tunnel-group VPNPhone general-attributes
address-pool VPN_Phone
default-group-policy PhoneVPN
tunnel-group VPNPhone webvpn-attributes
group-url https://x.x.x.x/VPNphone enable
username.....password..... for local authentication
Thank you,
Hardik
The first place to look would be the phone's console logs when trying to connect to the VPN.  From there you will see if the phone is failing to connect or if it's a certificate problem between what the phone knows of and what the ASA is using.
Hello Joseph,
Thank  you for responding. I disconnect my phone from outside connection and  plug it into LAN so I can pull logs. Once I pulled logs, I don't know  much, but here is what I found might be useful? Please advise. Anything  in perticular i should be looking for?
I see my login credentials:
Then I see this:
Thank You,
Hardik
I look for the URL first as a starting point in the logs, search for HTTPS://.  Then look for something about CERT HASH to see if there is a certificate issue.
Hello Joseph,
I do not see any "CERT HASH" in Console Logs. I see following https:// sites:
But then I see this:
This is what I see for HTTP://
Thank You,
Do you have host ID check disabled in CUCM for the VPN configuration?  The URL being an IP address will not match the certificate Common Name (CN).  You should see if this is a problem from the phone console log too.
Yes, I have already disabled Host ID Check option.
305
