cisco 7965 does not try to register with SIP firmware 9.3.1
Hi Have just purchased a 7965  hardware version 13 and converted it to SIP but for some reason, it does not try to register. I know that the xml is good as I it works with a similar 7965 phone with firmware version 8.5 however not with 9.3. The only requests the phone does apart from downloading the xml and firmware is ntp synchronisation and it stops. Can anybody point me in the right direction as I am clueless on how to solve it. The xml I am using is attached.
Chris
i have the same issue. did
i have the same issue. did you solve it?
Hall of Fame Super Gold
f you are NOT using any Cisco
f you are NOT using any Cisco-related call server, then I'd recommend you stay away from SIP version 9.X.  Use 8.5(4)S (and later) instead.
188
