Cisco 7970G touch screen issue
When someone utilizes the touch screen functionality of the 7970G phone it usually works. However, when you browse to a user's name via a directory and touch the name to dial that person the phone freezes up and will not work again until it is re-booted. I am able to successfully dial the same person when using the navigation buttons on the phone, there is only a problem when I try to use the touch screen to dial. Any ideas on why the phone is freezing up? Thank you.
Green
Re: Cisco 7970G touch screen issue
Using custom directory?
Can we reproduce this, so we can gather phone logs?
All phones?
I would go to last firmware first
I was not able to dial the person by touching the name in my 7975, i was not aware of that functionality, it only allows me to select it
Can u get the logs from IP Phone web page and upload them
Also let me know the exact firmware so I can try to reproduce
After some more digging I found out that I needed to upgrade my firmware. Thank you for the help.
154
