Cisco 7970G Troubleshooting
I am having a problem with a Cisco 7970G VoIP phone...when I power it up the mic button flashes red, then the green speaker button comes on for about 10-15 seconds. After that the speed dial buttons start cycling, at first the top two buttons flash orangish-red (one at a time) and then the buttons just start flashing green repetitively one at a time from top to bottom.
The phone display illuminates and shows the Cisco logo with a box in the lower right corner with a check mark in it. The display never advances and the speed dial buttons just alternately flash green until I unplug the phone.....seems like the boot cycle might be corrupted.
Can anyone confirm?
Hall of Fame Super Gold
Re: Cisco 7970G Troubleshooting
Your phone is trying to re-load firmware.
When connected to a CM or CME it would re-initialize itself.
You can also do that with the firmware files and a DHCP/TFTP server like tftpd32.
I have the tftpd32....just need to figure out where to get the firmware files. Thanks for the response.
You are welcome, please remember to rate useful posts with the scrollbox below.
157
