Cisco 7975 & Cisco 7965 Add Speed Dial Options to BLF's
Hi there,
I wanted to know if anyone was able to program speed dial for BLF keys or on sidecars on a UC560 System.  I have added personal speed dials and system speed dials, but through CCA i am unable to add speed dials through any extensions.  There isn't an option for it.  Is this possible or no?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hi HD,
I would have a look at the links on the page (great site )
http://uc500.com/en/enabling-presence-uc540
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
What is your ultimate goal? If you're just trying to setup Speed Dials then all you need is to configure the Speed Dial buttons under "Association Information" on the phone and not the BLF Buttons under the phone. If you want to monitor the extensions configured as BLF Speed Dials then you will need to configure Presence which monitors the extensions.
Yosh
HTH Regards, Yosh
Did you add the Speed Dial and or BLF lines under the modify buttons of the phones?
Yosh
HTH Regards, Yosh
Hi HD,
Cheers!
Rob
I know how to setup monitor extensions and I enabled SNR as well, but enabling presence seems like an unnecessary step.  I guess I could setup floating extensions with no voicemail and forward all calls to the appropriate number.
Yosh
HTH Regards, Yosh
Got it.  We are going to just stick with SNR then.  Thank you as you are correct with the answer.
2114
