Cisco 881 Router
Hello
I understand that the Cisco 881 is end of life.
But wanted to check if the Cisco 881 router support E1 cards?
I believe it supports FXO/FXS? how many FXO/FXS will it support?
Many Thanks
Kaushik
1 ACCEPTED SOLUTION
C881SRST-K9 PRODUCT
C881SRST-K9
PRODUCT DETAILS
Device Type Router - 4-port switch (integrated)
Enclosure Type Desktop
Data Link Protocol Ethernet, Fast Ethernet
Network / Transport Protocol L2TP, IPSec
Routing Protocol RIP-1, RIP-2, HSRP, VRRP, GRE
Remote Management Protocol Telnet, SNMP 3, HTTP, HTTPS, SSH
VoIP Functionality VoIP phone adapter
VoIP Protocols MGCP, SCCP, SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
Telephony Interfaces 1 line (FXO), 4 phone (FXS)
Compliant Standards IEEE 802.1D, IEEE 802.1Q
Power AC 120/230 V ( 50/60 Hz )
Dimensions (WxDxH) 32.5 cm x 24.9 cm x 4.4 cm
you can connect 1 line pstn and 4 analod phones
and dont forget to rate post
Hi Kaushik,You can check
Hi Kaushik,
You can check Table 2 of the following link
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Manish
C881SRST-K9 PRODUCT
C881SRST-K9
PRODUCT DETAILS
74
