10-20-2014 06:46 PM - edited 03-17-2019 12:37 AM
Recently we have deployed Cisco 8831 conference phone registered to CUCM 8.6.2 and realised that this phone is showing clear text on FAC during call setup. Once the call is connected, the display is back to normal.
Anyway to hide or encrypt the FAC on the phone display during call setup? Any advise will be appreciated. Thanks.
Solved! Go to Solution.
10-21-2014 01:16 AM
Check this bug if it helps.
Known Affected Releases: | (1) |
Known Fixed Releases: | (1) |
10-21-2014 01:16 AM
11-09-2014 10:55 PM
Hi Aman,
Any solution on this issue? Is it possible try upgrade to the latest version 8.6.2 SU5 ?
Thanks.
11-10-2014 12:22 AM
Hi ,
I suggest opening TAC case since fix is available in version 9.3(3)ES5 which u can get only from TAC or take suggestion of TAC whether upgradation of CUCM is the only resolution.
regds,
aman
11-10-2014 12:25 AM
Hi Aman,
Thanks for your suggestion.
