Cisco 887VA-V-W-K9 License
I've bought an Cisco 887VA-V-W, I can't activate the voice part of the ISR. I've accept the license end user agreement, reload the router but nothing works,
Here is the show ver :
ISR-TEST#sh version
Cisco IOS Software, C880 Software (C880VOICE-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:56 by prod_rel_team
ROM: System Bootstrap, Version 15.1(2r)T3, RELEASE SOFTWARE (fc1)
ISR-TEST uptime is 1 day, 2 hours, 1 minute
System returned to ROM by reload at 14:14:13 UTC Mon Mar 17 2014
System restarted at 14:15:13 UTC Mon Mar 17 2014
System image file is "flash:c880voice-universalk9-mz.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 887VA-V (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FCZ174990TU
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 Gigabit Ethernet interface
3 ISDN Basic Rate interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
1 DSP, 16 Voice resources
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        C887VA-V-W-E-K9       FCZ174990TU
License Information for 'c880-srst'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
And here the show license :
ISR-TEST#sh license
Index 1 Feature: advipservices
    Period left: Life time
    License Type: Permanent
    License State: Active, In Use
    License Count: Non-Counted
    License Priority: Medium
Index 2 Feature: SSL_VPN
    Period left: Not Activated
    Period Used: 0  minute  0  second
    License Type: EvalRightToUse
    License State: Not in Use, EULA not accepted
    License Count: 0/0  (In-use/Violation)
    License Priority: None
Index 3 Feature: ios-ips-update
ISR-TEST#
The ISR is regitered with my CUCM (v 7.1.5) but the voice Bri stay unregistered.
If someone as an idea on how to use the voice BRI on the ISR.
Mathieu
  • IP Telephony
VIP Purple
Hi Mathieu, what is the
Hi Mathieu,
what is the protocol u are using for regsitering with CUCM?
if using MGCP, try H.323. there is a bug associated
Unable to register both BRI ports of C887VA-V using MGCP
CSCuj54849
Symptom:
BRI/S0/SU0/P2 does not register successfully.
Conditions:
Using MGCP to register C887VA-V ports to CUCM
Workaround:
Use H.323 instead of MGCP
regds,
aman
VIP Purple
Hi Mathieu,
Hi Aman,Thanks for all your
Hi Aman,
Thanks for all your replies, i finally setup my ISR with H323 and everything is working. I'm waiting to see if there is a solution to use MGCP.
VIP Purple
Hi Mathieu,there was a recent
Hi Mathieu,
there was a recent discussion on same issue and issue has not been resolved even with CUCM 10
https://supportforums.cisco.com/discussion/12149611/unable-register-both-bri-ports-c887va-v-using-mgcp-bug-cscuj54849
regds,
aman
Hi aman,thanks for your reply
Hi aman,
thanks for your reply. I use MGCP for the gateway, I'll try to set up H323 to see if it's work.
Do you know when MGCP will be supported by the 887VA? Do you think I can use SCCP for the ISR?
Mathieu
VIP Purple
Hi Mathieu,
Hi Mathieu, I have checked the datasheet and says that SCCP is supported under Call-Control signalling. http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html regds, aman
242
