Cisco 8941 corporate directory
In the corporate directory on the 8941 I can't see the BLF fields that I can see on the 7900 series. i.e. I can't see the presence on there. Is this expected? I can't find anything about it anywhere!
Firmware version is 9.3(4) and UCM version is 9.1
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Dave,
I totally agree with you here I think the fact that the link I sent
doesn't mention "Directory" is a dead giveaway. There was this Bug/Enhancement
that speaks to this on 4th gen phones;
Presence enhancement
CSCtc73771
ymptom:
On a 79XX series phone the directory, call logs, and  call history (when you press the down key) you are able to see presence  status of the DN's if your subscribe search space allows (this is by the  phone icon, on hook for not busy, off hook for on a call, etc..).  On a  9971, 9951, and 8961 this behavior does not seem to be present.
Conditions:
Looking for BLF call lists on 4th gen phones.
Workaround:
None. This is an enhancement request for 4th gen phones.
I'm pretty sure there is still a bit of a gap in the feature parity here.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Hi Dave,
Does it work for Call History (Missed calls etc.)??
Cheers!
Rob
- Bob Marley
What is the exact model of these 7900 phones? If they are type A: 7910, 7940 and 7960, these phones do not support presence-enabled call and directory lists.
Please rate helpful answers!
Yeah, they work fine on our 7900 series (which are 7942G's btw), it's the 8941's where it doesnt. Thanks for that suggestion Rob! I'll take a look tomorrow. My gut feeling is that it doesnt.
Really I have a sneaking suspicion it's not supported yet, but I was hopeful someone would tell me otherwise!
Re: Cisco 8941 corporate directory
Hey Dave,
Good stuff
The reason I ask was that there is this note related to the 8941
but it does not mention the Directory lists;
Line Status for Call Lists
The  Line Status for Call Lists feature enables the user to see the  availability status of monitored line numbers in the Call History list.  The administrator enables or disables this feature using the Line Status  for Call Lists parameter in the Enterprise Parameters Configuration  window.
When the Line Status for Call Lists parameter is Enabled, the phone  line numbers in the Call History register Line Status notifications and  an icon appears next to each Call History item in the Call History list.  The icon notifies the user that the lines are in one of the following  states:
  • Unknown
  • Idle
  • Busy
  • DND
When the Line Status for Call Lists parameter is Disabled, the phone  line numbers in the Call History list do not register the Line Status  notifications.
This feature is supported on the following Cisco Unified IP Phones (SCCP and SIP):
  • Cisco Unified IP Phone 8941
  • Cisco Unified IP Phone 8945
From;
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/8941_8945/firmware/9_3_1/release_notes/P415_BK_R3969224_00_rn-9_3_1-8941-8945_chapter_00.html#P415_RF_L77EE5A3_00
Cheers!
Rob
- Bob Marley
So, the verdict!
I get presence fine in missed/received/placed
I don't get it in corporate directory.
I don't have that field in enterprise parameters, but I do have "BLF for Call Lists" which does the same thing and is enabled.
This must be an 8941 accessing that service thing. I really suspect it's not supported, which is annoying
Hi Dave,
CSCtc73771
ymptom:
Conditions:
Workaround:
Cheers!
Rob
- Bob Marley
Sorry for the slow response on this Rob. It looks like we're out of luck then! Here have some Karma/correct answer/kudos or whatever it is on here and thanks!
429
