10-26-2013 08:35 AM - edited 03-16-2019 08:05 PM
Dears,
I have cisco 8941 connected to CUCM 9.1, I tried to upload backgroung image unsuccesfully. where I already upload the background for cisco 7942 succesfully.
I already used (640x480x24) for cisco 8941.
Appreciate your support,
10-26-2013 08:55 AM
Are you sure from the below:-
1-Full-size image
640 pixels (width) x 480 pixels (height)
123 pixels (width) x 111 pixels (height)
2- Did you restart TFTF servers , if you have pub and sub ) . Upload for both TFTP and restart both.
3-disable and reenable the Enable Caching of Constant and Bin Files at Startup TFTP service parameter (located in the Advanced Service Parameters).
4- Tell us the path on your TFTP management is /Desktops/640x480x24/
5- Share also the firmware of your IP phone 8941 , is it 9.3 ?.
Thank you
Please rate all useful information
10-26-2013 11:05 AM
you won't be able to do custom background for 8941 before 9.2.3.5
Upgrade phone fw and try again
Haitham
10-27-2013 07:38 AM
Thanks all for your reply,
I already uploaded the image for 7942 successfully.
For the requirement that you mentioned I already applied it except the 3rd item, please can you tell me the exact path for it??
The 8941 version is sccp 9-3-2-11
10-27-2013 01:26 PM
Hi Ali
1-3rd item :-
Go to system - service parameters - select your Publisher - select TFTP then you will get a page , on this page press advanced you will find down
Enable Caching of Constant and Bin Files , disable and enable it means disable save then enable save
2- This step should be done after restart TFTP servers.Then check.
3-If all not work , try to reset fatory the IP phone.
Thank you
10-29-2013 07:53 AM
Dear Islam,
I applied all the steps, but still facing the same problem
10-29-2013 11:05 AM
Do you see the options??
Do you see blue images/no images instead of thumbnails??
If the first, re-create the List.xml file from scratch, DO NOT copy from any page using ctrl + c, manually copy all, there are hidden characters that get copied and affect this.
If the second, the problem is either with the images (wrong specs or path, etc), or with the formatting of the path on the .xml file.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-29-2013 01:01 PM
I didn't get your points (Do you see the options?? and Do you see blue images/no images instead of thumbnails??), but you can find below the XML that I created:-
by the way I already upload backgroung image successfully for IP phone 7942
Any advice??
11-12-2013 06:58 AM
Hello ,
I hope you are ok. I Have applied image background for 7942G but now, I have two CP-8941 that do not want to register. Please can you help. resolving this issue.
Thank.
