Cisco 8945 Bluetooh headset, Does hookswitch option has been deleted?
Running: CUCM 9.1.1, Cisco 8945G (firmware 8945.9-3-2-11).
I have installed a bluetooh headset with a Cisco 8945, right now is "working" but call can't be answer if the Phones' s Headset button is not pressed so it 's not a "wireless" solution. For 79XX series the hook-switch option has to be enable to enable this feature for Plantronic headset but I can't find that option in CUCM for 8945 phones.
Additionally, we are in the process to buy some Plantronics headset but would like to know if cable APC-82 EHS (replacing lifter) will work for 8945 phones
Thanks in advance for your help.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Paul Kent-Smith
Hi Leo
I believe for the 89xx series phones that the 'Electronic Hookswitch feature' is configured from the preferences menu directly from the phone.
Take a look there and report back if this works for you
Thankyou. This worked for me on the 8945 handsets.
Leo Salcie,
I have used the Plantronics headsets with my phone and they are great. I am unsure about the APC-82 EHS working with the phone, but Headsets Direct has a great guide to find what headsets are compatible with your phone.
It looks like these are compatible from what I see from Headsets Direct's website, any H Series and wireless headset that they sell. There are also some others.
This information can be found at:
http://www.headsetsdirect.com/cisco-headsets-everything-you-need-to-know-for-cisco-telephones?utm_source=Forums&utm_medium=Rick&utm_campaign=Marketably
