Cisco 8945 - Handset hang up issue with Internal busy call
We are facing an issue with 8945.
When we call (with a 8945) an other internal 8945 which is busy, we have the following softkey on the screen: End of call or recall.
     - If we only hang-up with handset without to push one of the two softkeys, the call stays active during 15-20s before to hang-up.
     - If we push the softkey End of call, the call is immediately terminated
     - If we push the softkey recall, we have the recall message
Our environment is:
CUCM / CUPS: 9.0.1.10000-21
Cisco 8945 SIP9-3-2-12
Thank you very much if you can help us
Best regards
Maxime
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Cisco 8945 - Handset hang up issue with Internal busy call
Hi Maxime,
Looks like this bug
8945 SIP: unable to end call via hook-switch when calling a busy line
CSCud43423
Symptom:
Phone-A:
CP-8945 (SIP8941_8945.9-3-2-12)
Phone-B:
phone type and firmware does not matter
scenario:
- Phone-B is busy
- Phone-A calls Phone-B
- Phone-A gets "Busy" on the display and hears the "Busy-tone" in the handset
- Phone-A places the handset back on the phone (to hang-up)
-> but nothing changes:
- display of the Phone-A still shows the connection to Phone-B
- the busy-tone can still be heard in the handset of Phone-A
- if you press end call, the call ends fine.
- If the call is connected, placing the handset down will end the call.
Conditions:
Phone-A:
Phone-B:
Workaround:
Use softkey endcall instead of hook-switch or downgrade firmware to 9.3.1
Known Affected Releases:
(1)
9.3(2)
Known Fixed Releases:
(2)
9.3(2)ES2
9.3(2)SR1
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Hi Maxime,
Looks like this bug
CSCud43423
Symptom:
Phone-A:
Phone-B:
scenario:
- Phone-B is busy
Conditions:
Phone-A:
Phone-B:
Workaround:
(1)
9.3(2)
(2)
9.3(2)ES2
9.3(2)SR1
Cheers!
Rob
- Bob Marley
Thank you very much for your answer
Hi Maxime,
You are most welcome my friend
Cheers!
Rob
PS: if you are ever looking for bugs related to the 8900 series of IP phones
they are actually found under the 6900 series for some strange reason
- Bob Marley
238
