05-12-2012 09:07 AM - edited 03-16-2019 11:07 AM
Hi Guys,
Just to check if 8961 could support IPMA features like filtering of calls and enabling/disabling of "Call filtering"?
cheers,
Tony
05-12-2012 10:39 AM
It doesn't look like the 89XX or 99XX phones support IPMA from this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsipma.html#wp1071963
05-12-2012 08:06 PM
Oh dear. Is there any document beside the above which states clearly that IPMA is not supported by 89XX series?
12-02-2013 12:07 PM
Hello Tacl,
when you install the following device pack, cucm Unified reporting:Unified CM Phone Feature List
tells you that from now on the 8961 and 9951 and 9971 are supportet for IPMA:
cmterm-devicepack9.1.2.11013-1.cop.sgn
Greetings
