08-15-2013 01:47 AM - edited 03-16-2019 06:52 PM
Dear All,
I have one issue with 9951-Sip phone . i registerd some 9951 phone in CME.9.1 i also have service module (SM) with unity express 8.6.6 i went to unity express adding CME user there not showing SIP phone only i can see SCCP phones
somebody have any idea about this issue ....
is it possible to convert SIP firmware to SCCP...?
Could you please help me...
Solved! Go to Solution.
08-15-2013 07:06 AM
Hey Leo,
Hope all is well buddy!
The 9900 series are "native" SIP endpoints which is a change in direction
from Cisco as you nicely noted
The Cisco Unified IP Phone 8900 and 9900 Series of endpoints provide a wide range of form-factors and physical characteristics, including models with and without LCD displays and speaker phones and with varying numbers of line keys. Likewise, some models in this series provide support for Bluetooth and/or 802.11, such as the Cisco Unified IP Phone 9971, while others do not. In general, all of the phones in the Unified IP Phone 8900 and 9900 Series provide the same set of enterprise IP telephony features such as call hold, call transfer, call forwarding, and so forth. The Cisco Unified IP Phone 8900 Series supports either SIP only or both SCCP and SIP signaling protocols (dependent on phone model) for registering and communicating with Cisco call processing platforms. The Cisco Unified IP Phone 9900 Series models support only SIP signaling when registering and communicating with call control.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/endpnts.html#wp1309417
Cheers!
"Smooth" Rob
"A smile relieves a heart that grieves"
- Stones
08-15-2013 04:17 AM
I don't understand the first question as CUE doesn't care whether a phone is SCCP or SIP. Please rephrase what you're asking. No, you cannot convert the 9951 to SCCP.
08-15-2013 04:26 AM
Sorry, but this is not a challenge Jonathan. I'm asking because I'm new to VoIP.
You CAN'T convert 9951 to SCCP or you can't convert 9951 to SIP?
I thought that Cisco phones are "native" to SCCP.
08-15-2013 07:06 AM
Hey Leo,
Cheers!
"Smooth" Rob
- Stones
08-15-2013 04:35 PM
Thanks "Smooth" Rob.
I fat-fingered the rating and gave you a "4" instead of a "5" Sorry.
Back to the subject at hand ... So this means that I should be able to get the phone to connect to my home Asterisk. I presume that it uses the same SIPmacaddress.cnf.xml from the 7970?
08-15-2013 08:59 AM
Hi Muhammed
In case with 9951 phone you must input only extension of phone.
Cue module not see sip phones and it impossible to change sip to sccp on 99xx phones
Sent from Cisco Technical Support Android App
08-16-2013 03:42 AM
Dear all ,
my all 9951 phones are registering CME.9.1 and SM (service module ) i want to add all 9951 in unity express 8.6.6 but the prblm is i went to unity express for user adding i cant see any 9951 sip phone unity Express web page and CME web page .....
08-16-2013 03:58 AM
Use CLI, not GUI, and you will be able to make everything work.
08-16-2013 09:21 AM
thanks for all replay......Bro
I am using CME.9.1 plus SM (service module engine) Unity Express everything is router only after SM configuration we have loging CME.we page and unity we page is require...i didnt found any unity CLI configuration
somebady have any idea about Unity express CLI configuration could please help me...
i am waiting for your valuable replay..
