Cisco 9971 Code display when use FAC
Hi Guys,
I saw  in this discussion bellow that another colleague had the same problem in the last year, when the user put the password to FAC the password appear in display. My quesiton is: Still not had solution about this problem?
(FAC doesn´t work with this telephone model?)
https://supportforums.cisco.com/message/3151942#3151942
Wilson
Hall of Fame Super Red
Hi Wilson,
This new Firmware should have resolved this issue;
Cisco Unified IP Phone 8961, 9951, and 9971 (SIP) Release Notes for Firmware Release 9.2(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/firmware/9_2_1/release_notes/9900_8900_921.html#wp219168
Forced Authentication Code and Client Matter Code Support
The Forced Authentication Code (FAC) and Client Matter Code (CMC) Support feature extends the FAC and CMC features to more Cisco Unified IP Phones.
FAC controls the types of calls that certain users can place. When placing a call, a user receives a prompt to enter a valid authorization code before the call is made.
CMC enables a user to specify that a call relates to a specific client matter. When placing a call, a user can enter a code to indicate the type of call being placed (for example, to a specific customer).
These enhancements are supported on these Cisco Unified IP Phones (SIP):
Cisco Unified IP Phone 9951
Cisco Unified IP Phone 9971
Cheers!
Rob
Hi Rob,
This problem that occur is a bug? I saw the cisco site that there is version cmterm-9971.9-2-2SR1-9.cop.sgn that is more new version. I can use this version?
Wilson
Hi Wilson,
Yes, you could try the newest firmware 9-2-2sr1
Here is the related bug;
CSCta93018            Bug Details
FAC is showing in clear text
Symptom:
While making a call outside through PSTN or Trunk and FAC is compulsary for that Route pattern and User provided the correct FAC. It is showing in clear text.
Conditions:
Workaround:
Further Problem Description:
StatusStatus
Open
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phones 9900 Series
Technology Technology
1st Found-In 1st Found-in
9.0(0)
Cheers!
Rob
Hi Rob,
I putted the version 9.2.2, but, didn´t worked. You have another idea about this?
Thanks.
Wilson
Hi Wilson,
Thanks for posting back with your test results +5 I guess this is why
the bug/enhancement does not show a "fixed-in" version.
Cheers!
Rob
Is this problem resolved? I am also facing the same issue.
Hall of Fame Super Gold
Sev. > 2 & no major account screaming == bug never fixed.
Re: Cisco 9971 Code display when use FAC
We have a customer in UAE with approx 3700 IP phones with 7911, 7945,7965,7975 etc. Now they want to replace all of that with 9971...It's creating a chaos...What is the solution.
Rgds,
Partha
You should ask that to Cisco. This is just a discusson forum.
Hi Acharyr123,
What the problem with 9971 we re having?
Wilson
Bevilacqua,
The problem is solved in CUCM version 8.6
Wilson
I am using 8.5…What is the solution with 8.5?
Rgds,
Partha
Hi Partha,
My Customer have version 7.1.3 and when tryed configure the FAC in 9971 it presented this problem. I opened a case in Cisco TAC and was informed that the problem is solved only CUCM 8.6.
Follow below:
About the version 9.2.1, I commented that it is the version that started the CMC/FAC support for 9951, 9971 and 8561. But unfortunately the BUG CSCta93018 was found. However there isn’t a published release with the fix yet.  Once this BUG is solved, a firmware with the fix will be published and will be able to be used with any CCM version.
However I have found an intermediate solution which has been used for other clients and worked properly (but not officially tested by Cisco). This intermediate solution requires the following actions and combination between Firmware and CCM versions:
A.  Upgrade 9951 firmware to the latest version, 9.2(1).
Release notes with firmware upgrade instructions found here:
http://www.cisco.com/web/software/282074288/50113/cmterm-9951.9-2-1-readme.html
B.  Upgrade Call Manager to version 8.6.X, as 8.6.1.20000-1:
Release notes with upgrade instructions found here:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/rel_notes/8_6_1/cucmbe6k-rel_notes-861.html#wp1944944
So there are two options:
1-      Wait BUG be resolved and upgrade phones to the firmware with the fix, maintaining your current CCM version.
2-      Upgrade your CCM and Phones to the versions 8.6.X and 9.2.1 respectively.
If these steps are taken in that order you should see the problem be rectified.
In my opionion, I Believe that the Cisco not will solve this bug in version previous 8.6
Wilson
Hi Acharyr123,
This problem was solved in the last version CUCM 8.6. I did test in my laboratory and worked.
Wilson
I´m using he latest firmware sip9951.9-3-1-33 with Callmanager 7.1.5 and still the FAC is in clear text.
Any solution?
Thanks.
Hi Saavedra,
In my Customer, this problem only solved after to do upgrade CUCM 8.6 .
Wilson
hello wilsonsant
en what version did you fix this problem?
1140
