12-05-2013 07:02 AM - edited 03-16-2019 08:43 PM
I'm running CUCM 9.1. When a call arrive Cisco 9971 is not displayed the Divert option to transfer the call to voicemail manually. I have read this option is only available using Softkey but how can I add this option if Softkey on Cisco 9971 can't be modfy? Am I losing something?
# Feature Name | # Dedicated Feature Button | # Programmable Feature | # Softkey |
# Divert | # | # | # X |
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
Solved! Go to Solution.
12-05-2013 07:16 AM
Hi Leo,
I thought the access to this Softkey was controlled via the
Feature Control Policies Maybe you could check there.
Device > Device Settings > Feature Control Policy
Cheers!
Rob
"When it comes to luck you make your own "
- Springsteen
12-05-2013 07:16 AM
Hi Leo,
Cheers!
Rob
- Springsteen
12-05-2013 07:33 AM
Hi rob,
I didn't know that . Thanks a lot!
