Community Member
CISCO 9971 hanging problem
why this cisco 9971 hangs if it is ideal for a long...and however that fone can be pinged from the network and on switch with the command show cdp neighbors it show as IEEE PD only and not the cisco 9971....plz answer sir
1 ACCEPTED SOLUTION
No, on CUCM server
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: CISCO 9971 hanging problem
Not sure what you mean by 9971 hangs... If you are refering to the screen turning off when the phone is idle, this is probably the power saving feature configured. Check this setting under Product Specific Configuration Layout in CUCM.
Please rate helpful answers!
Community Member
Hi dear Amine
.....no no i didnt mean to say that ....as the power saving feature is differnt that can be defined from the cucm.....actuallly phone goes unregistered but in cisco switch it can be checked that its taking power (show power inline) as 15.4Watt and a IEEE PD .....instead Cisco 9971
What does the app log has to say about that unregister, does it show a reason code for it??
java
java
Community Member
Jaime Sir i will look and get back to  sir...i guess app log must be in phone itself right?
No, on CUCM server
java
java
Community Member
Jamie Sir thnx
ohkk CUCM server......i havent explored yet sir. can u tell me in which menu or submenu i can get the app log for a device...i have cucm 9..
You need to use RTMT to access those logs, you cannot get them directly from the server.
java
java
Community Member
oopsss.....ohh real time monotoring tool.....yeahh yeah i knw tat sir.....its a add-on i hav to download....ok i will try Sir
268
