01-23-2014 03:52 AM - edited 03-16-2019 09:23 PM
We have a lot of 9971 phones installed.Everything is fine.
Just one phone make calls involuntary,without any user,day or night,no matter.
The phone has BLF buttons applied to phone and to ext. modules.
The phone calls one by one all DNs,which is programmed as BLF on the phone.but not on the modules.
For example.
Phone BLF buttons.
1111
1112
1113
The phone periodically calls 1111,1112,continuously and stops suddenly.
Today we've changed the phone to the new one,changed ext. modules also.Few minutes ago we've been informed about same problem-the phone calls himself to BLF assigned DNs.As temporary solution,i've moved all BLFs from phone to module,and now it's ok.
SW ver : 9-3-1-33, as we have some problems with ver 9-3-4-24.
The previous phone,which we changed was screen corrupt,the phone works,but screen is white blank...
I'm out of adequate technical explanation...
What can you advice?
Thanks.
01-23-2014 04:04 AM
seems to be bug
9971 Phone - Automatic Dial, when press on Edge of Phone Screen frame
9971 auto dials the Speed Dial and BLF SD as Phantom calls
regds,
aman
01-24-2014 02:27 AM
Updated yesterday to ver. 9-4-1-9
Let's eee what i will face with.
Thanks.
02-04-2014 09:38 PM
Very strange.
Same problem.
Phone make calls again...
Have no tech. ideas for ..
Any ideas?
06-24-2015 06:19 AM
Everybody,Thanks for help.
The problem was the pgone owner was cleaning it's screen with alchohol based solution.
It caused problems with touchscreen.
08-28-2014 12:47 PM
I am seeing this on 9971 devices running sip9971.9-4-1-9. I have watched the display cycle through the BLF speed dials then stop and dial one. This happened on a 9971 where the first BLF is the line, the second BLF is set to " Mobility" and the last four have been programmed for internal 5 digit speed dials. I am now testing with the first BLF is the line, the second BLF is set to " Mobility" and the third has an internal 5 digit speed dial.
This was a bug in 9.3.1 and was stated as fixed in 9.3.2. https://tools.cisco.com/bugsearch/bug/CSCuf13779
