Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco 9971 phone cant establish call via sip trunk
We have CUCM 9.1 and 9971 and 7945 phones are registered.
We have SIP trunk to FreePBX (Asterisk). All other Cisco 79xx serias phones can make call across the SIP trunk to the extension on
FreePBX (Asterisk) , except Cisco 9971 IP phones.
I have tried with disabling "video capabilies" on 9971 phone. Also "Advertise 722" disabled on 9971. Still didn't work.
When I make call across SIP trunk. I am getting busy tone. But other Cisco 79xx phones can call same extension across the same SIP trunk...!
only 9971 phone cant call extension across the sip trunk.
9971 Phone extension is 200 and I am Calling 901 across SIP trunk.
At CUCM RTMT log I get below error,
407 Proxy Authentication Required
2013/11/04 17:48:11.917|CC|OFFERED|31263163|31263164|200|901|901|SEPF84F57959B25|CONF_BRDG
2013/11/04 17:48:11.917|SIPT|31263164|UDP|OUT|192.168.25.30|5060|CONF_BRDG|192.168.25.25|5060|1,100,13,1.371^*^*|8797|bd2ce500-2771a59b-2ed-1e19a8c0@192.168.25.30|INVITE
2013/11/04 17:48:11.918|SIPT|31263164|UDP|IN|192.168.25.30|5060|CONF_BRDG|192.168.25.25|5060|1,100,238,1.2391^192.168.25.25^*|8798|bd2ce500-2771a59b-2ed-1e19a8c0@192.168.25.30|407 Proxy Authentication Required
2013/11/04 17:48:11.919|SIPT|31263164|UDP|OUT|192.168.25.30|5060|CONF_BRDG|192.168.25.25|5060|1,100,238,1.2391^192.168.25.25^*|8799|bd2ce500-2771a59b-2ed-1e19a8c0@192.168.25.30|ACK
2013/11/04 17:48:11.920|SIPL|31263163|TCP|OUT|192.168.25.30|5060|SEPF84F57959B25|192.168.25.122|51349|1,100,238,1.2391^192.168.25.25^*|8800|f84f5795-9b250009-520a461e-7b60cd8c@192.168.25.122|407 Proxy Authentication Required
2013/11/04 17:48:11.966|SIPL|31263163|TCP|IN|192.168.25.30|5060|SEPF84F57959B25|192.168.25.122|51349|1,100,13,84.36^192.168.25.122^*|8803|f84f5795-9b250009-520a461e-7b60cd8c@192.168.25.122|ACK
Attached some part of SDL logs
From: "TEST" <sip:200@192.168.25.30>;tag=3241~1df8cd1c-1453-4df4-a4b4-33afcc6c21ac-31263143
To: <sip:901@192.168.25.25>
Date: Mon, 04 Nov 2013 13:34:16 GMT
Call-ID: cb7a0180-2771a258-2da-1e19a8c0@192.168.25.30
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:192.168.25.30:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3413770624-0000065536-0000000122-0504998080
Session-Expires:  1800
P-Asserted-Identity: "TEST" <sip:200@192.168.25.30>
Remote-Party-ID: "TEST" <sip:200@192.168.25.30>;party=calling;screen=yes;privacy=off
Contact: <sip:200@192.168.25.30:5060>
Max-Forwards: 69
Content-Length: 0
00128071.000 |17:34:16.034 |SdlSig   |UdpSendReq                             |start                          |EnvProcessUdpPort(1,100,238,1)   |SIPUdp(1,100,63,1)               |1,100,13,1.350^*^*                       |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  varId=0 varIpAddr=3232241945 varIpPort=5060 varFamily=2
00128071.001 |17:34:16.034 |AppInfo  |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0
00128071.002 |17:34:16.034 |AppInfo  |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb2d84d18
00128071.003 |17:34:16.034 |AppInfo  |EnvProcessUdpPort::fireSignal - SEND, destination = 192.168.25.25:5060
00128071.004 |17:34:16.034 |AppInfo  |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 1035, 192.168.25.25:5060)
00128072.000 |17:34:16.035 |AppInfo  |EnvProcessUdpHandler::handle_input - handle = 332
00128073.000 |17:34:16.035 |AppInfo  |EnvProcessUdpHandler::handle_input   Status: 0, Id: 0
00128074.000 |17:34:16.035 |SdlSig   |UdpDataInd                             |wait                           |SIPUdp(1,100,63,1)               |EnvProcessUdpPort(1,100,238,1)   |1,100,238,1.2356^*^*                     |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  varStatus=0 varId=0 varSrcIpAddr=3232241945 varIpPort=5060 varFamily=2
00128074.001 |17:34:16.035 |AppInfo  |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 564 from 192.168.25.25:[5060]:
[8566,NET]
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.168.25.30:5060;branch=z9hG4bK34e4a3d6bab;received=192.168.25.30
To: <sip:901@192.168.25.25>;tag=as0b9cf958
CSeq: 101 INVITE
User-Agent: Asterisk PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="6618aa4e"
Content-Length: 0
00128075.000 |17:34:16.035 |SdlSig   |SIPSPISignal                           |wait                           |SIPHandler(1,100,72,1)           |SIPUdp(1,100,63,1)               |1,100,238,1.2356^192.168.25.25^*         |*TraceFlagOverrode
00128075.001 |17:34:16.035 |AppInfo  |//SIP/Stack/Info/0x0/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 (SIP_NETWORK_MSG), for event 1 (SIPSPI_EV_NEW_MESSAGE)
00128075.002 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x0/sipTransportProcessNWNewConnMsg: context=(nil)
00128075.003 |17:34:16.035 |AppInfo  |//SIP/Stack/Info/0x10903a10/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
00128075.004 |17:34:16.035 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_TRYING value=500 retries=6
00128075.005 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x10903a10/sipSPISendAck: Sending ACK to the transport layer
00128075.006 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x10903a10/sipSPITransportSendMessage: msg=0xb19669a0, addr=192.168.25.25, port=5060, sentBy_port=0, is_req=1, transp
00128075.007 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x0/sipInstanceGetConnectionId: gcb=0x10903a10 is already on connection=0xfc55310 context_list
00128075.008 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x10903a10/sipTransportLogicSendMsg: Set to send the msg=0xb19669a0
00128075.009 |17:34:16.035 |AppInfo  |//SIP/Stack/Transport/0x10903a10/sipTransportPostSendMessage: Posting send for msg=0xb19669a0, addr=192.168.25.25, port=5060, connId=0 for U
00128075.010 |17:34:16.035 |AppInfo  |//SIP/Stack/Error/0x10903a10/sipSPIHandleAuthChallenge: Error getting credentials
00128075.011 |17:34:16.035 |AppInfo  |//SIP/Stack/Error/0x10903a10/act_sentinvite_new_message: Error handling AuthenticationChallenge
00128075.012 |17:34:16.035 |AppInfo  |//SIP/Stack/States/0x10903a10/sipSPIChangeState: 0x10903a10 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
00128075.013 |17:34:16.035 |AppInfo  |//SIP/Stack/Info/0x10903a10/ccsip_set_cc_cause_for_spi_err: Categorized cause:47, category:181
00128075.014 |17:34:16.035 |AppInfo  |//SIP/Stack/Info/0x10903a10/sipSPIInitiateDisconnect: Initiate call disconnect(47) for outgoing call
00128076.000 |17:34:16.035 |SdlSig   |SIPSPISignal                           |wait                           |SIPUdp(1,100,63,1)               |SIPHandler(1,100,72,1)           |1,100,238,1.2356^192.168.25.25^*         |*TraceFlagOverrode
00128076.001 |17:34:16.035 |AppInfo  |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 192.168.25.25:[5060]:
[8567,NET]
ACK sip:901@192.168.25.25:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
00128075.015 |17:34:16.035 |AppInfo  |//SIP/SIPHandler/ccbId=3241/scbId=0/ccsip_api_call_disconnected: ccb->cc_disc_cause (47); ccb->sip_disc_cause(407)
00128075.016 |17:34:16.035 |AppInfo  |//SIP/SIPHandler/ccbId=3241/scbId=0/findDevicePID: Routed to SIPD by ccbId/scbId
00128077.000 |17:34:16.035 |SdlSig   |UdpSendReq                             |start                          |EnvProcessUdpPort(1,100,238,1)   |SIPUdp(1,100,63,1)               |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  varId=0 varIpAddr=3232241945 varIpPort=5060 varFamily=2
00128077.001 |17:34:16.035 |AppInfo  |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0
00128077.002 |17:34:16.035 |AppInfo  |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xb2d84d18
00128077.003 |17:34:16.035 |AppInfo  |EnvProcessUdpPort::fireSignal - SEND, destination = 192.168.25.25:5060
00128075.017 |17:34:16.035 |AppInfo  |//SIP/Stack/States/0x10903a10/sipSPIChangeState: 0x10903a10 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
00128077.004 |17:34:16.035 |AppInfo  |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 427, 192.168.25.25:5060)
00128078.000 |17:34:16.035 |SdlSig   |SIPDisconnInd                          |restart0                       |SIPD(1,100,74,38)                |SIPHandler(1,100,72,1)           |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  CcbId= 3241 --TransType=2 --TransSecurity=0 PeerAddr = 192.168.25.25:5060 Sip_disc_cause= 407 cause=47 isReasonHdrVal= F
00128078.001 |17:34:16.035 |AppInfo  |SIPD(38) - getKeyBasedOnCiAndBranch: AddressingElement branch is 0 and ci is 31263143  mapKey is 31263143
00128078.002 |17:34:16.035 |AppInfo  |SIPD(38) - getCdpcPidGivenCcbidAndCi: found Cdpc Pid (1,100,75,296) for mapKey 31263143
00128079.000 |17:34:16.035 |SdlSig   |SIPDisconnInd                          |outCall_proceeding             |SIPCdpc(1,100,75,296)            |SIPD(1,100,74,38)                |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  CcbId= 3241 --TransType=2 --TransSecurity=0 PeerAddr = 192.168.25.25:5060 Sip_disc_cause= 407 cause=47 isReasonHdrVal= F
00128079.001 |17:34:16.035 |AppInfo  |SIPCdpc(296) - tryAnotherDynamicAddr: isDynamicTrunk 0
00128079.002 |17:34:16.035 |AppInfo  |ViprUtils::uploadVCRifRequired VcrUploadNeeded[1] FeatureData NOT added
00128079.003 |17:34:16.035 |AppInfo  |SIPCdpc(296) - uploadVCRifRequired: VcrUploadNeeded 1
00128080.000 |17:34:16.035 |SdlSig   |CcDisconnInd                           |wait                           |Cc(1,100,213,1)                  |SIPCdpc(1,100,75,296)            |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=31263143 CI.branch=0  c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=134217749 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=true TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
00128081.000 |17:34:16.035 |SdlSig   |CcDisconnInd                           |tcc_transit_call_proceeding5   |Cdcc(1,100,212,170)              |Cc(1,100,213,1)                  |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=31263143 CI.branch=0  c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=134217749 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=true TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
00128081.001 |17:34:16.035 |AppInfo  |Cdcc::isStaticTransactionApplicable
00128081.002 |17:34:16.035 |AppInfo  |processCCMFeatureData: operationIeIdd=0
00128081.003 |17:34:16.035 |Created  |                                       |                               |MatrixControl(1,100,135,159)     |Cdcc(1,100,212,170)              |                                         |NumOfCurrentInstances: 1
00128082.000 |17:34:16.035 |SdlSig   |DropPartyReq                           |await_command                  |MatrixControl(1,100,135,159)     |Cdcc(1,100,212,170)              |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] ClearType= 0
00128083.000 |17:34:16.035 |SdlSig   |AuDisconnectRequest                    |wait                           |ConnectionManager(1,100,207,1)   |MatrixControl(1,100,135,159)     |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=31263142 CI2=31263143 sc=0 disconnType=1 ssReason=0 clearType=0 IF1Created=F IF2Created=F party1.mMediaCoordinatorNodeId=0 party2.mMediaCoordinatorNodeId=0 party1.dtmCall=0 party2.dtmCall=0 reconnectPending=F forceStop=F
00128083.001 |17:34:16.035 |AppInfo  |!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI(31263142,31263143),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
00128084.000 |17:34:16.035 |SdlSig   |AuDisconnectReply                      |dissolving                     |MatrixControl(1,100,135,159)     |ConnectionManager(1,100,207,1)   |1,100,238,1.2356^192.168.25.25^*         |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=31263142 CI2=31263143 sc=245 disconnType=1 ssReason=0 clearType=0 IF1Created=F IF2Created=F party1.mMediaCoordinatorNodeId=0 party2.mMediaCoordinatorNodeId=0 party1.dtmCall=0 party2.dtmCall=0 reconnectPending=F forceStop=F
00128084.001 |17:34:16.035 |AppInfo  |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=1, party 2 videocapable=1
00128084.002
Everyone's tags (2)
set your asterisk to allow anonymous connections from CUCM.
Please remember to rate useful posts, by clicking on the stars below.
It is still not working even after setting asterisk to allow anonymous connections from CUCM.
only 9971/video phones are not able to make calls through trunk.
Other IP phones (79xx) are able to make call thriugh sip trunk.
any suggestion ?
Rgds
Rajesh
Any suggestion on the issue ?
Rgds
Rajesh Kumar
Looks like SDP is missing from your INVITE.  Enable MTP, this might help.
Hi Rajesh,
Are you facing this issue for Incoming call as well?
Please provide detail trace from CUCM and also let us know the call flow.. how it is?
Nishant Savalia
Regards, Nishant Savalia
1042
