Community Member
cisco 9971phone unified camera not wokring
                Hi All,
   I  am facing the issue that when i connect  cisco 9971 phone to network its initializing all  the procedure including camera(red light on ) and after few second
i got error that unable to power the unified camera . On the other hand  same phone model are working fine ...
Any help will be higly appreciated.
Br,
SHIB
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hello Shaikh
On the 9971 device page at Product Specific Configuration Layout disable the Power Negotiation
Leonardo Santana
Hall of Fame Super Silver
is the phone connected to Cisco switch or other vendor switch?
When you browse accessories on the phone does it list the camera?
Is video and camera enabled on the phone configuration?
Chris
Community Member
The phone is connected HP switch.Second, after connect to the network it shows in accessories with USB symbol just for 5 sec then disappear given eror "unable to power the camera.Third ,yes all enabled.
Hello Shaikh
Leonardo Santana
Exactly, hence my question around the switch vendor. I had a customer using Extreme switches few years back where it took me a while to figure out this issue, after reviewing console logs it was evident the phones do not negotiate power requirements for the cameras with non Cisco switches. Disabling power negotiation does the trick.
HTH,
Chris
Yes Chris, i had this issue with HP switches.
Leonardo Santana
Community Member
Thankyou guys to help me out..:)
Community Member
I recently ran into an issue
I recently ran into an issue where the Camera suddenly quit being recognized by the phone. Removing and reinserting the camera did not solve the issue. Neither did resetting all settings on the phone through the administrator settings. I found that downgrading the firmware, and then re-upgrading to the original running version would solve the issue. It seems like the driver was being corrupted somehow.
Running Firmware: sip9971.9-4-1SR1-2
Downgraded to: sip9971.9-4-1-9
Upgraded to : sip9971.9-4-1SR1-2
This happened on two different phone and the above resolution fixed it on both phones.
772
