Cisco and Linksys Compatibility
NeilFalcon
I currently have 2 x Cisco 3560 non POE switches and now need to run VOIP on the switches, due to the lack of AC power near the phone POE injectors aren't really an option, so i need to add another switch.
I want to add a LINKSYS POE switch for the phones and then link the Linksys switch to the 3560 already installed so they are also part of the network, but i'm not to sure if it will work or if it will effect the VOIP in any manner.
Any info would help.
Neil
acampbell
Neil
This should not be a problem.
Just make sure that if you have more that 1 Vlan for example
Vlan 10 for Data
Vlan 100 for VOIP
Make the connection between the 3560 and the linksys a 802.1Q trunk.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
