Community Member
Cisco ata 186 and fax?
Hello!
i have a problem with sending fax through a cisco ata 186 adapter, i can send to some numbers.. but thats not many.
i have a ata 186-l2-A adapter with Version: v3.1.0 atasccp connected to a cisco callmanager express router with cme 4.1
i have attached the debug (prserv.exe)
get a lot of
speedup@XXXXXXXXXXX?
i read about a bug with speed problem:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdv90018
but that should be solved in the adapter i got (186-I2)
so anybody that has experience or run into a similar problem please try to help me!
//Kristoffer
Hall of Fame Super Gold
Re: Cisco ata 186 and fax?
ata and fax don't always go ver well along. Tobegin with can you upgrade to latest FW and tryagain ?
Also note that by general consensus, the most stable results are obtained with ata H.323 image.
Community Member
Paolo's right, the general consensus is to use H323 with ATAs and fax machines.
This conversation:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1dddc6e7
contains a lot of information on this subject and may help you out.
Are the problems you're having related to the numbers you are trying to call, or just with sending/receiving faxes?
Have you tried attaching an analog phone to the ATA and making a test call? This will highlight the problem.
Glenn
Community Member
okej, im going to try that but i have never worked with h323 can you maybe give me a complete "must have" example config?
or it will take days for me to google it up...:p
Community Member
Hi Glen,
I am having the exact same problem as the original poster. When I connect an analog phone to the ATA and make a voice call, there is no problem. I want to change to H323 image and try my luck.  But the link you posted takes me to the IP Telephony forum, not to the particular discussion on the issue. Could you be kind to post the correct link?
regards,
Abebe
669
