Cisco ATA 186 - inline problem
hi all ,
i am facing inline error on fax machine wich is connect with cisco ATA .
please advice .
regards
1 REPLY
Re: Cisco ATA 186 - inline problem
We're going to need more information to help. What is the problem? Does the fax machine issue the error? What version of firmware is the ATA running? What is the call flow for fax calls?It may be helpful to review the fax section of the ATA Admin guide and verify that it's configured to support faxing.
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/index.htm
-Felipe
134
