Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco ATA 186
Dear Friends
I am having an issue with the ATA186, the fax transmission issues are occuring, i have seen on the forum the replies to the similary kind of problems occuring to users, i am still unable to understand the changes that are given on the cisco site on the ATA. i would like to request for a simple way of solving this issue. the fax machine i am using is panasonic KX-FL612
Cheers
Aamir
VIP Super Bronze
Re: Cisco ATA 186
Change the fax transmit and receive speeds on the fax machine to be no higher than 14400bps.
The ATA186 does not support fax relay, modem pass through, or modem relay. All the gateway can do is fall back to fax pass through if you've configured it properly which does not support speeds above 14400bps.
Bronze
Re: Cisco ATA 186
Also make sure you turn off error correction mode if you can.
Please rate if this helps.
300
