07-29-2014 11:54 AM - edited 03-16-2019 11:33 PM
Dear all; I just stuck on configuring the cisco ATA 187with cme v.9.1. It is not registering at all after configuring as SIP. My configuration is as follows.If there is any further command or step needed, please do let me know.
My configuration is
voice register global
mode cme
source-address 172.16.4.21 port 5060
max-dn 4
max-pool 4
load ATA-187 ATA187.9-2-3-1
authenticate register
tftp-path flash:
file text
create profile sync 0011055035546058
voice register dn 1
number 130
voice register pool 1
id mac 2834.A2F6.9688
type ATA-187
number 1 dn 1
username ata password ata
codec g711alaw
When I am checking the device URL, I am seeing following log and when I am changing dn values and all, it is effecting over there too.
2000/01/03 07:41:23:170 No CTL installed
2000/01/03 07:41:23:174 IP phone is in non-secure mode
2000/01/03 07:41:23:515 Succeed to get XMLDefault.cnf.xml
2000/01/03 07:41:25:905 File Not Found : CTLSEP34A2F6968801.tlv
2000/01/03 07:41:25:909 No CTL installed
2000/01/03 07:41:25:913 IP phone is in non-secure mode
2000/01/03 07:41:26:265 Succeed to get XMLDefault.cnf.xml
2000/01/03 07:41:28:665 File Not Found : CTLSEP34A2F6968801.tlv
2000/01/03 07:41:28:670 No CTL installed
2000/01/03 07:41:28:674 IP phone is in non-secure mode
2000/01/03 07:41:29:026 Succeed to get XMLDefault.cnf.xml
2000/01/03 07:41:31:425 File Not Found : CTLSEP34A2F6968801.tlv
What might be the issue and the device status is registering.
07-29-2014 12:54 PM
You need to configure the MAC address as:34A2.F696.8801 as thats what its going to register as since the ATA has 2 analog ports.
07-30-2014 10:26 PM
Dear Mr.George;
Thanks for your reply. I couldn't do the reply from there, that's i am making the reply on the text. Here, i am trying to register one port on the ATA. But, how come, other also came in to the picture. So that, i need to configure the other port also as compulsory. In the web url of the device, it is showing, both ports are on registering status. At least one should register, if the configurations are correct. And when i am trying to restart the device from the pool or voice register global, it is telling " no contact info available". If i need to configure the second mac, do i need to configure the second mac mapped with another DN. Could you please clarify this.
Thanks.
08-02-2014 04:15 AM
hello
can you share with us the below:-
1- R#sh ip dhcp binding
2-R#sh voice register pool 1 brief
3-Can you do the below " i need to check without load command" as a test:-
no load ATA-187 ATA187.9-2-3-1
no tftp-path flash:
no create profile
tftp-path flash:
create profile
thanks
please rate all useful information
07-29-2014 10:58 PM
In addition to George words , try to do the below:-
voice service voip
sip
registrar server
thanks
07-30-2014 10:33 PM
Dear Mr. Kamal;
I tried that already. Still the same. From the cme , when i am trying to give a restart it is giving a message like " no contact info available for the pool". I believe some security issue, but i have given authenticate command in global and username and password in the pool.
Thanks.
07-30-2014 11:15 PM
Can you try giving below command once under voice register global and then reset the phone.
authenticate realm all
Suresh
07-31-2014 01:11 PM
Dear suresh;
Thanks for the reply. I done that already. By checking cisco docs and some other blogs and all, i went through different dimentions. I believe, without this also, it should register because everything on the same subnet and there is no domain aspect here. But anyway, i given that also. Once again thanks for the reply and expecting a extended querry on this.
BR
07-31-2014 01:36 PM
Did you already try changing the MAC address, if you look at the logs, its looking for the MAC address i mentioned.
07-31-2014 09:59 PM
Dear,
Have you configured sip-ua as well on cme ? it may be the issue with improper interface binding.
Can u plz attach show run here.
And what about changing MAC as suggested by George.
Suresh
08-01-2014 03:46 AM
Dear George and Suresh;
I didn't try to change the mac address. Actually, the changes are reflecting over the device while changing the DN number from cme, that means interface binding has done right ?. In the device it is showing both port status as registering which i didn't initiate (second one). Here is my sh run and device status info.
device status
MAC Address | 28:34:A2:F6:96:88 | |
Phone 1 DN | 130 | |
Status1 | Registering | |
Phone 2 DN |
Status2 | Registering | |
App Load ID | APP187.9-0-3-1 | |
Boot Load ID | 1.8.0.6 | |
SW_Version ID | 187.9-0-3-1 | |
HW Reversion ID | Rev.06 | |
Serial Number | FCH181481KD | |
Module Number | 550 | |
Product ID | ATA-187 | |
Message Waiting (Line 0) | Enable | |
Message Waiting (Line 1) | Enable | |
UDI |
| ATA187 | |
| FCH181481KD | |
| V01 | |
| Cisco Analog Telephony Adapter 187 | |
Time | 11:10:51 PM | |
Time Zone | Pacific Standard/Daylight Time | |
Date | 01/04/00
sh run
Current configuration : 10822 bytes
! Last configuration change at 13:04:33 UTC Thu Jul 31 2014 by saic
version 15.2
hostname SAICSTORE-VG
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone UTC 3 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 172.16.4.21 172.16.4.25
ip dhcp pool SAIC-POOL
network 172.16.4.0 255.255.255.0
default-router 172.16.4.21
option 150 ip 172.16.4.21
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-1872387581
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1872387581
revocation-check none
rsakeypair TP-self-signed-1872387581
crypto pki certificate chain TP-self-signed-1872387581
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31383732 33383735 3831301E 170D3134 30313232 32303430
32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38373233
38373538 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C63D D6890926 B579307C 0DA15F71 11BA0A9A 9A06326A E1852E2D E086D5A1
DC3AC10E 2383DC7F EFA4F66F EAF05E00 B4BA2743 0E12803E 79897AFB A52644BF
CAD92C20 897A6850 7452A408 A76C6269 848CD6E9 785DD119 B631A88D FD6225B3
2AAF4E2E 5D6F0294 6A4DCEC4 B6419CDF 3FBC5D91 DE3C8E02 9A5BDC23 93D7C8BE
8DE50203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14841F77 62329BB3 0DEA355E 9B65D3B4 61EEBD68 22301D06
03551D0E 04160414 841F7762 329BB30D EA355E9B 65D3B461 EEBD6822 300D0609
2A864886 F70D0101 05050003 81810011 BC2F7B69 CA2DD70C 6BEBC325 1485DC16
45F8E4C6 87A01ACC FA65FF1A 7ECC3C0B 29BFAD54 D55DA54B E855043B 75EF3560
4B9712D4 279A14FE F387C7F1 0343D924 2725216F 1D5DA7BC 78FEE75C 18477AA0
53A0EA32 D745FFA4 5D02248D 8D45EF54 1F628766 67114795 A9C97EFA F1CCD9EE
573ABE37 477C1C72 7A34DAD2 FE98AB
quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
registrar server
mode cme
max-dn 4
max-pool 4
tftp-path flash:
file text
create profile sync 0011055035546056
voice register dn 1
number 130
type ATA-187
number 1 dn 1
codec g711alaw
voice translation-rule 1
rule 1 /.*\(1..\)$/ /\1/
voice translation-rule 11
rule 1 /.*\(1..\)$/ /40320\1/ type any national plan any isdn
voice translation-rule 12
rule 1 // // type any unknown plan any isdn
voice translation-rule 21
voice translation-rule 22
rule 1 // // type any national plan any isdn
voice translation-rule 31
rule 1 /.*\(1..\)$/ /+97440320\1/ type any international plan any isdn
voice translation-rule 32
rule 1 // // type any international plan any isdn
voice translation-profile EMR
translate calling 11
translate called 12
voice translation-profile INT
translate calling 31
translate called 32
voice translation-profile LOC
translate calling 21
translate called 22
voice translation-profile PSTN
translate called 1
license udi pid CISCO2921/K9 sn FCZ180460P4
hw-module pvdm 0/0
username saic privilege 15 password 0 P@$$2@(@0ne
username cisco privilege 15 password 0 P@$$2@(@0ne
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-10,16
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.4.21 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
tftp-server flash:APPATA187.9-2-3-1.img.sgn
tftp-server flash:ATA187.9-2-3-1.loads
tftp-server flash:BFSATA187.9-2-3-1.img.sgn
tftp-server flash:KNLATA187.9-2-3-1.bin.sgn
control-plane
voice-port 0/0/0:15
translation-profile incoming PSTN
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.16.4.21 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
switchback method graceful
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 999 pots
translation-profile outgoing EMR
destination-pattern 999
no digit-strip
port 0/0/0:15
dial-peer voice 8 pots
translation-profile outgoing LOC
destination-pattern 9[4].......$
port 0/0/0:15
dial-peer voice 900 pots
translation-profile outgoing INT
destination-pattern 900T
port 0/0/0:15
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 50
ip source-address 172.16.4.21 port 2000
time-zone 37
time-format 24
date-format dd-mm-yy
keepalive 10
max-conferences 8 gain -6
call-forward pattern .T
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 octo-line
number 100
description +97440320100
ephone-dn 2 octo-line
number 101
description +97440320101
ephone-dn 3 octo-line
number 102
description +97440320102
ephone-dn 4 octo-line
number 104
description +97440320104
ephone-dn 5 octo-line
number 105
description +97440320105
ephone-dn 6 octo-line
number 106
description +97440320106
ephone-dn 7 octo-line
number 107
description +97440320107
ephone-dn 8 octo-line
number 108
description +97440320108
ephone-dn 9 octo-line
number 109
description +97440320109
ephone-dn 10 octo-line
number 110
description +97440320110
ephone-dn 11 octo-line
number 111
description +97440320111
ephone-dn 12 octo-line
number 112
description +97440320112
ephone-dn 13 octo-line
number 113
description +97440320113
ephone-dn 14 octo-line
number 114
description +97440320114
ephone-dn 15 octo-line
number 115
description +97440320115
ephone-dn 16 octo-line
number 116
description +97440320116
ephone-dn 17 octo-line
number 117
description +97440320117
ephone-dn 18 dual-line
number 118
description +97440320118
ephone-dn 19 dual-line
number 119
description +97440320119
ephone-dn 20 dual-line
number 120
description +97440320120
ephone-dn 21 dual-line
number 121
description +97440320121
ephone-dn 22 dual-line
number 122
description +97440320122
ephone-dn 23 dual-line
number 123
description +97440320123
ephone-dn 24 dual-line
number 124
description +97440320124
ephone-dn 25 dual-line
number 125
description +97440320125
ephone-dn 28 dual-line
number 128
description +97440320128
ephone 1
description Operator
mac-address 7C95.F33F.4EF6
button 1:11
ephone 2
description Arshad
mac-address 2C3E.CF7B.92E2
button 1:20
ephone 3
description Shabeer
mac-address 2C3E.CF7B.9305
button 1:21
ephone 4
description Zaki-Ati
mac-address 2C3E.CF7B.92FF
button 1:22
ephone 5
description Mohamed Aziz
mac-address 2C3E.CF7B.903C
button 1:23
ephone 6
description Faiz Ali
mac-address 2C3E.CF7B.92F3
button 1:19
ephone 7
description Meeran Office
mac-address 2C3E.CF7B.92E5
button 1:25
ephone 8
description MAIN STORE
mac-address 2C3E.CF7B.9312
button 1:28
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 172.16.4.21
end
08-01-2014 04:49 AM
Firmware is not updating ON ATA ?
Can you plz post show flash:
Suresh
08-02-2014 02:23 AM
Yes, it is not updating. That's the reason. It is because of, when i do the restart from global mode or from pool , it is telling, " no contact info available". If that is ok, it will download the firmware. I had uploaded the new firmware, but, it is not taking it. I will post the sh flash later, because there is some conectivity issue in remote. Once it is ok, I will take it and post.
08-10-2014 07:03 AM
Dear all;
It is started working. I don't know what was the effect of doing like that. I just re-entered the tftp mappings again and restarted. After that, it is registered.It was just a try from my side, it worked out.
Thanks.
03-02-2017 03:33 AM
Hi Mani,
I am facing the same issue with my system, Can you please brief which tftp mappings you re-entered and then did u restart the router as well.
