cisco ata-187 with cme cisco2921
hi all,
how to register the cisco ata 187 with cisco cme 2921
i am running cme version of 8.8
thanks
cyril
Green
Cyril,
It seems that the ATA187 will NOT be supported on CME till ver 9.0
see
https://communities.cisco.com/message/72987
Alex
Regards, Alex. Please rate useful posts.
I'm running cme 9 and it still not supported
when you find the debug
the ATA ask for CTLSEPxxxxxxxxxxxx.tlv file
but it can get the conf file
can't find any work arround
Green
This is all a bit confusing
The CME admin guide infers that the ATA187 is supported
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1248625
Restrictions
•H.323 trunk calls are not supported.
•Hardware conferencing with DSPFarm resource is not supported on Cisco ATA-187 in Cisco Unified CME 9.0. With the correct firmware (9.2(3) or a later version), local three-way conferencing is supported.
However on the software download page I can only find ATA 187 firmware 9.2.1 as the latest
What version of ATA187 is on your CME ?
Alex
I was facing the same problem with CME, version 7.1. Got a reply from TAC saying this wasn't supported, and will hopefully be supported on upcoming versions of CME. In the mean time, we are getting the ATA 187 replaced with VG202 devices.
Cheers
Binu
2754
