Cisco Attendant console 8.0 and CUCM 9
i have a customer that wants to migrate to CUCM 9 and they currently has Cisco Unified Attendant Console 8.0 running.
i have read at this below link that with the Availability of CUCM 8.0 in June 2010, the Cisco Unified Attendant Consolereached end of life.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-mobile-communicator/guide_c07-622127.pdf
Does this mean that it wont work with CUCM 9?
1 ACCEPTED SOLUTION
The legacy AC that came with
The legacy AC that came with CUCM has been removed, the latest version that could get it was 7.X and only on upgrades. All the services and config elements have been removed, so, no, it won't work.
Anything above 8.X+ requires to purchase a CUxAC, directly from ARC, or any other AC you want.
java
if this helps, please rate
www.cisco.com/go/pdi
java
thanks a milion.. i just
thanks a milion.. i just needed a second opinion to confirm what i read, since im not too familiar with Attendant Console on the whole.
thanks again!!!
55
