Cisco based Fax or FOIP
I am aware of a product that can be deployed as a Fax Server appliance from Cisco which is based on Right Fax. I would like to know if the VOIP gateway supports Fax. Can it perform Fax Server Role where it will handle incoming and outgoing fax requests and forward it to appropriate users just as it can handle Voice over IP, can it also perform Fax over IP and forward incoming and outgoing faxes to exchange users.
I am pretty new to the VOIP and FOIP so your help would be appreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco based Fax or FOIP
Yes, of course.
When you want to know about something, begin with the search box on cisco,com
1 REPLY
Yes, of course.
189
