Cisco bug CSCse46832 - need Cisco TAC engineer
kevintang
Any Cisco TAC engineer here?
I got this Cisco Bug CSCse46832. The work around is contact Cisco TAC engineer.
Kevin
Erick Bergquist
Level 6
Level 6
I suggest you open a TAC case online or call into 800-553-2447.
This is a discussion forum and someone from cisco may answer here but it is best to open a TAC case/SR so your case can also be associated to the bug id.
CSCse46832 Bug Details
Headline
Extension Mobility LOGOUT Device Profile can be deleted when in use
Product ciscocm
Feature ciscocm
Severity 2
Status Resolved
First Found-in Version 5.0(2)
First Fixed-in Version 5.1(0.30), 5.1(0.9901.033), 5.1(1.1000.007), 5.1(1.2000.002)
Release Notes
Symptom:
Unable to log out of Extension Mobility after deleting the Logout Device Profile.
Error occurred while retrieving information from database. [379] No LOGOUT device profile
The Logout Device Profile should not be deleted.
Conditions:
This happens when a Device Profile being used as a Logout Profile is deleted. The user interface should prevent this action.
Workaround:
Contact TAC for manual workaround.
Further Information
ssh into server using admin account to identify all affected devices. Example:
admin:run sql select name,ikdevice_defaultprofile from device where ikdevice_defaultprofile not in (select pkid from device)
name ikdevice_defaultprofile
SEP0009B7DA0528 22d8ece3-3f62-4220-a1a8-d8e1fb1de6de
note the entire query from 'run..' through 'device)' needs to be contiguous with no carriage returns or linefeeds.
gogasca
Level 10
Level 10
Hi Kev,
Im a TAC Engineer.
For: CSCse46832
Our workaround
1. Create a new Device Profile to replace the deleted profile. (Device - Device Settings - Device Profile)
1a. Note the PKID of the newly created device profile (in the URL of the CCMAdmin interface)
2. Find the PKID of the phone currently logged in.
3. Create a remote support account via Platform Administration.
4. Login to the Publisher using the remote support account.
5. Enter the command "su - informix'
6. Enter the command "dbaccess"
7. Using the Select Database menu select the current CCM database.
8. Using the query builder, enter the following SQL query string.
update device
set ikdevice_defaultprofile = ''
where pkid = ''
9. Use the menu to run the previous query. This should return "One Row Updated".
10. Proceed to logout the EM phone either through the web interface or through the phone interface.
As previous post suggested I would recommend you to open a case with us if you are not confortable doing this.
I have logged a TAC case, The TAC engineer said he need the remote access, because he will uses the root access, and can not give the password to me.
Help!
I know it does not sound good, but you will have to give TAC access to the box. You can do it by using meetingplace, which is a new tool and works gr8.
