Cisco Business Edition 6000
Hi All.
I have a challenge deciciding which version of the Ciso Business Edition 6000 installation guide to use to prepare me for installing the device. The thing is I don't know which version the device will come in so I don't know which of the guides to read. It may be possible that the content of the guides might be similar and so anyone will do, but it is also possible that there might be major differences.
I would just like to know which you would advise I use. It might be helpul as well to know which version ships with the device.
Thanks.
  • IP Telephony
VIP Purple
Hi Kofon,
You can check Purchase Order for exact CUCM version.
Further, the installation of Call manager is almost same for all linux versions.
regds,
aman
Hall of Fame Super Silver
+5 for Aman for good tip, in addition I believe the shipping version is still 9.1.2, unless you ordered otherwise.
HTH,
Chris
Unless you're doing 10.X which has the extra step for "call home" in the wizard, any 8.X or 9.X will do the job.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
You might also find this
You might  find this BE6000 Software Load Summary of use.
Karthik Sivaram
VIP Purple
Hi Karthik, Thanks a lot for
Hi Karthik,
Thanks a lot for sharing the DOC.
regds,
aman
115
