03-26-2009 10:44 AM - edited 03-15-2019 05:07 PM
Call Manager 4.2.3 SR2a - get a "Conference Bridge Unavailable" error message on the phone when they try to dial a meet-me number or initiate an Ad-Hoc Conference. It does not affect all phones on the system, only a few?
Solved! Go to Solution.
03-26-2009 11:20 AM
go to serviceability -> service center
java
if this helps, please rate
03-26-2009 10:58 AM
You need to check the MRGL for the affected device and ensure you have one assigned to it.
03-26-2009 11:00 AM
All Phones are assigned to the Conference MRGL - and the Device pool also points to this MRGL.
03-26-2009 11:08 AM
try restarting the IPVMS service or doing a sccp/no sccp if using HW CFB
java
03-26-2009 11:16 AM
Where is the IPVMS service?
03-26-2009 11:20 AM
java
03-26-2009 11:39 AM
Restarted service, I will make some test calls to double check
03-27-2009 10:20 AM
that worked.
