Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco Call Manager 7.1.3 LDAP integration Lotus Domino
I installed Cisco Unified Communication Manager 7.1.3 and added all end-users to the system. I would like to Integrate using LDAP with Lotus Domino which is a LDAP server. Do you have a guide which outlines the step for this integration?
Once I synchronize the database on Call Manager with Domino LDAP server will the users be dis-associated with their phones?
what is the impact on the already configured system?
How do I mitigate if there ie an impact?
Re: Cisco Call Manager 7.1.3 LDAP integration Lotus Domino
These are the only LDAPs supported
Table 17-2     LDAP Directory Support
LDAP Directory Type
Cisco Unified CM 5.x
Cisco Unified CM 6.x
Cisco Unified CM 7.x
Microsoft AD 2000
Microsoft AD 2003
Microsoft AD 2008
Microsoft  ADAM 2003
Microsoft LDS 2008
Yes
Yes
Yes
Cisco Unified CM 7.1(3) or later release is required for Microsoft ADAM  and LDS.
Netscape 4.x
Yes
Yes
No longer supported1
iPlanet 5.0
Yes
Yes
iPlanet 5.1
SunOne 5.2
Yes
Yes
Yes
SunOne 6.x
No
Yes
Yes
OpenLDAP 2.3.39
OpenLDAP 2.4
No
No
Yes2
1 The directory vendor indicates that this solution has reached End  of Life.
2 This directory type is supported only with Cisco  Unified CM 7.1(2) and later releases.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Based on the supported LDAP Servers, Lotus Domino is not listed, does that mean it is not supported?
Or will it fall under the category of OPenLDAP?
No, OpenLDAP is it's own category/LDAP product.  However, you may look into the possibility of replicating your Lotus Domino information using an OpenLDAP solution.  I'm not sure if this would be a viable option but it may be worth researching.
Hailey
Please rate helpful posts!
I believe some people have tried the integration using openLDAP as option, but this has not been tested and is not supported by Cisco.
You're free to give it a try.
java
java
Thanks team for the information.
Are you saying that some persons have used OpenLDAP as the LDAP server type however LDAP server is  really Lotus Domino?
Yeah, I think Java is saying that you can try to integrate with Lotus by faking out the CUCM server and choose OpenLDAP as the source.  However, it's not guaranteed to work as it's not tested or supported by Cisco.
Hailey
Indeed. I found reference to some cases where they tried this, but most of them just ended telling they would work this out with their Domino engineer, so I cannot confirm if they ever got this working.
java
java
1832
