Cisco Call Manager 9.1
     I have installed call manager 9.1 (UCSInstall_UCOS_9.1.2.11900-12) on VMWARE workstation 10.0 in my Lab, after the installation went fine when I am logging to the call manager using the GUI and CLI I get this error.
ERROR-UNSUPPORTED: Partitions unaligned
Your help will be appreciated
2 ACCEPTED SOLUTIONS
Hi Syed.
Did you use an OVA Template to deploy your CUCM?
Please have a look to the following doc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_2/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912.pdf
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re: Cisco Call Manager 9.1
Read this thread , this can help you to find answer.
https://supportforums.cisco.com/thread/2234742
Manish
Rate all the helpful post.
Hi Syed.
Carlo
I need to understand what does the error means and what if its left alone ? I havent used the OVA template, I made a customized virtual machine using Vmware workstation 10, if I would have used ESXI i would have used the OVA template.
Message was edited by: syed khan
Manish
860
