Cisco Call Manager 9 ELM question
Hello everyone!
We start using ELM for Call Manager Licensing and I just can not understand they way it works. I am used to DLUs and can not undertand the new scheme
Just to make is clear:
We have
Enhanced (9.x) - Unified CM Available - 180 Installed
Does it mean we can register 180 IP phones?
And we also have
Used - 8, Required
What is meant by Required?
Thank you!
1 ACCEPTED SOLUTION
VIP Purple
Installed means Total licenses available : 180
Required means Used :8
Unsed means Left or available to be used.
can u share from ELM--monitoring ---Dashboard /License Usage[Chart View] .You need to check the license usage where u get InCompliance status.
regds,
aman
VIP Purple
I think u are using UCL Enhanced licences.180 means you can 180 devices are supported.
required means 180 are total/installed  , out of which 8 have been used or required and 172 should ne UNUSED.
can u share the snapshot of license ?
regds,
aman
Yes, sure, here are the snapshots
Still not sure what Required is. Is it just used or we require any other licence?
VIP Purple
regds,
aman
So, Total license 180 means I can register 180 devices?
Used: 8, but we have added 24 phones, why used is just 8?
The first screen shot is Dashboard /License Usage[Chart View] screenshot
Can you pls tell me what Unassigned Devices 24 means on the second screeshot?
And what is Enhanced, Basic and Essential?
Thank you!
Hall of Fame Super Silver
No, CUCM 9 with ELM does not track devices directly it tracks users. With Enhanced UCL you can have a single device assigned with user (via device owner ID), with UCL Enhanced PLus 2 devices and with CUWL up to 10 devices.
Chris
Did not really understand.. What is Device Owner ID?
Field on the phone config page. For proper license tracking you need to ensure you select the owner of the phone (user) in that field. Otherwise all phones depending on a model will either be tracked and Essential, Basic or Enhanced users.
HTH,
Chris
Ok, got that. This is it says Unassigned devices 24 - it means 24 phones are registered but were not assigned a user ID. Thanks!
If we dont utilize users, and as I can see we have 180 licenses, how many phones can we register?
VIP Purple
Just refer slide 9 of attached link. [+5] to Mr. Chris.
https://communities.cisco.com/docs/DOC-33631
regds,
aman
Sorry, I am not authorized to that page
Re: Cisco Call Manager 9 ELM question
Yes, it did not really helped..
Ok,  Enhanced, Basic and Essential are types of phones, I got that
Still not sure about Unassigned Devices and these 2 questions
Thank you for your prompt replies!
VIP Purple
Hi ,
please find attached.
regds,
aman
Ok, Thank you, it makes more sence now.. But anyway, according to the snapshot below, we have 180 of some licence with 18 required. What does these numbers mean? Does it mean that I can register 180 up to Enhanced type IP phones? (including Basic and Essential?) And what does 18, 21 and 9 mean? Number of users I need to register for those phones?
It means you are entitled to 180Enhanced UCSL users (users with up to 2 devices), you have 18 such users currently provisioned and 132 still available. This does not mean you can have 180 such devices, it means you can have 180 users with 2 devices such as phone or softphone assigned to them or any 79XX, 89XX, 99XX phones.
The 21 and 9 are basic (69XX phone) and essential (3905, 6901 phone), since you don't have any of these licenses, they are being borrowed from the upper tier.
HTH,
Chris
408
