Community Member
Cisco Call manager connection with Dialogic IVR
We are having cisco call manger 4.1.3 and we want to use a custom Built IVR with Dialogic E1 Card. Does any one have any idea how can configure the gateway with E1 connected to Dialogic card? when it receives a call from PSTN E1 to send it to IVR.
Hall of Fame Super Gold
Re: Cisco Call manager connection with Dialogic IVR
I think an H323 configuration is better for that. Example:
network-clock-participate wic X
network-clock-select 1 E1 X/Y
isdn switch-type primary-net5
controller e1 x/y
clock internal
primary-group timeslots 1-31
dial-peer voice 100 pots
destination-pattern 5551234
incoming called-number .
direct-inward-dial
huntstop
no strip-digits
port x/y:15
dial-peer voice 101 voip
destination-pattern 555....
preference 2
no vad
codec g711u
session target ipv4:x.x.x.x
This way calls to 5551234 will go to IVR.
All other will go to CM.
Note the GW also has powerful IVR features using either CUE or TCL/IVR.
Community Member
Actually i want to use this IVR instead of IPCCX (IP-IVR). Any call coming to the gateway from PSTN should go to the this custom built IVR. and then this IVR will do call treatment and send it back to the CCM to transfer the call to any Phone. Did u ever came across this solution before.
thanks
The configuration I've sent above does that. Supposedly the GW has two E1 ports, one for PSNT, one for the IVR. I've not detailed the config for E1 ports.
It is not very optimal, as each call will take two channels on the IVR interface.
Depending on your IVR needs, suggest you re-evaluate the cisco solutions like CUE, that are definitely competitive.
285
