Cisco Call Manager replication issue
Hello
We are running a cluster of 3 servers with Cisco Call Manager version 6
I have noticed that the replication status is 3 on all servers and from the CM Database Status I can see  queue of updates are stuck
I have restarted Pub and one Sub but the status is still 3 and queue status is still the same
Is there anything I can do to make it work?
Thank you
Hello,Can you please try
Can you please try below command and in order to fix this issue
utils dbreplication stop on the subscriber and on the publisher. Wait the process finish on the sub and go to the pub
wait for a few minutes for it to finish
utils dbreplication dropadmindb on the publisher
wait for it to finish
utils dbreplication dropadmindb on the subscriber
utils dbreplication reset all on the publisher
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Thank you,
Thank you,
I will try them tomorrow, but I thought restarting the servers will also reset the replication
Btw, there was a time difference on the servers due to NTP failure and I have just noticed that Pub can not see one of the Subs, the replication status is 0 and
g_cucs01_ccm6_1_2_1000_13    2 Active   Connected       0 Sep 15 10:21:37
g_cucs02_ccm6_1_2_1000_13   11 Active   Connected       0 Sep 15 10:35:19
g_cucs03_ccm6_1_2_1000_13   19 Active   Dropped     92939 Aug 20 07:51:14
g_cucs08_ccm6_1_2_1000_13   18 Active   Local           0
Dear Nadeem,Is restarting the
Dear Nadeem,
Is restarting the servers the same as issuing these commands?
59
