Cisco caller name not appear
mohamed sebaey
I have CUCM integrated with my Ericsson system and i have AA on Ericsson. Ater i get connected to AA , it asks for enter extension number, when i enetered ext number for Cisco IP phone number , i get the call with unknown number. below is my debug for IP phone number 39946?. I used MGCP integration get CUCM and Ercisson.
*Nov 13 12:47:17.863: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8  callref = 0x00FB
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18394
                Preferred, Channel 20
        Facility i = 0x9FAA068001008201008B0100A1100201010201553008820301B850860101
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Called Party Number i = 0x81, '39946'
                Plan:ISDN, Type:Unknown
        Shift to Codeset 4
        Codeset 4 IE 0x31  i = 0x80
debug isdn q931 is              ON.
NGHA-HASA-VG#
*Nov 13 12:47:17.875: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80FB
        Channel ID i = 0xA98381
                Exclusive, Channel 1
*Nov 13 12:47:17.875: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8  callref = 0x80FB
        Facility i = 0x9FAA06800100820100A10C020101060528EC2C00018400
        Progress Ind i = 0x8088 - In-band info or appropriate now available
*Nov 13 12:47:17.919: ISDN Se0/0/1:15 Q931: RX <- FACILITY pd = 8  callref = 0x00FB
        Facility i = 0x9FAA06800100820100A406020101810101
*Nov 13 12:47:26.851: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8  callref = 0x80FB
        Facility i = 0x9FAA06800100820100A10C020102060528EC2C00028400
        Connected Number i = 0x0081, '39946'
*Nov 13 12:47:26.983: ISDN Se0/0/1:15 Q931: RX <- FACILITY pd = 8  callref = 0x00FB
        Facility i = 0x9FAA06800100820100A406020102810101
*Nov 13 12:47:26.983: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00FB
*Nov 13 12:47:27.659: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80FB
        Cause i = 0x8090 - Normal call clearing
Gergely Szabo
please make sure you check the "Display IE delivery" checkbox. If it does not work, you may also try the "Send Calling Name In Facility IE" checkbox.
Also, is this Q-Sig?
G.
Hi Gergely
Is this under gateway ?. if yes , already done. Yes i use Qsig.Please find my conf under Controller
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
isdn bind-l3 ccm-manager
isdn send-alerting
isdn sending-complete
no cdp enable
hmm, I don't have any other clues, really. Sorry about that.
G.
Hi.
Can you please indicate the version of cucm you are running?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
