Cisco CallManager in "cm service" alternating status running and not running
Hi Guys,
I did upgrade CUCM 7.1.3 for CUCM 8.6.2 and verify that the service CallManager in "cm service" stay not running after restart it did running, but, after more or less one minute the servivce staty not running again. I did restart many time the service and the CUCM, but, the problem continue.
Any have Idea about this.
Wilson
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Cisco CallManager in "cm service" alternating status running
correct, you can obtain the MAC by issuing "show status" from the CLI.
You use the LICENSE MAC for VMs.
Be aware that unless this is for lab/testing purpose your deployment is not supported by Cisco because of that upgrade path (nothing before 8.0(2) is supported on VM)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Wilson,
Do you have CUCM feature license for version 8 installed? That can cause it.
HTH,
Chris
Hi Chris,
As told for Rob the CUCM was installed in VMWare 4.1 ESXi. I Will verify about the license.
Wilson
Hall of Fame Super Red
Hi Wilson,
The Callmanager Service won't stay started until the 8.x Software feature License
for 8.x has been loaded.
If you ordered the 8.6 upgrade DVD's from Cisco via PUT (Product Upgrade Tool)
the PAK should be included and can be submitted to receive the Software feature
license
Cheers!
Rob
Hi Rob,
Thank You for your contact. I was with this suspect. I installed first VMWare ESXi 4.1 in a one UCS C210, after then install CUCM 7.1.3, after did the upgrade for version 8.2.6. I Will verify the License and inform for you the results. A one question: I need inform the MAC Address about UCS C210 Server to generate the license?
Wilson
java
java
407
