08-30-2012 03:11 AM - edited 03-16-2019 12:56 PM
Hi all,
some month ago i set up a Cisco 2811 with CME 8.6 IOS is c2800nm-adventerprisek9-mz.151-4.M4.bin. Inventory is VIC2-2BRI-NT/TE and PVDM2-16.
My Problem is That ISDN Calls IN and OUT have no function. When i dial out after seconds the status ist "unknown Number" (in the Phonedisplay).
The BRI an Voice-Port cfg:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn tei-negotiation preserve
isdn point-to-point-setup
isdn incoming-voice voice
end
voice-port 0/2/0
compand-type a-law
cptone DE
Other Voive cfg:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice translation-rule 10
rule 1 /^894xxxx0$/ /1001/
rule 2 /^894xxxx9$/ /1002/
voice translation-rule 20
rule 1 /^0/ //
voice translation-rule 30
rule 1 /^1001$/ /89xxxx0/
rule 2 /^1002$/ /89xxxx9/
voice translation-rule 110
rule 1 /^2426180$/ /5000/
rule 2 /^.*/ /5000/
voice translation-rule 120
rule 1 /^9/ //
voice translation-rule 130
rule 1 /^/ /9/ type unknown unknown
rule 2 /^/ /90/ type national national
rule 3 /^/ /900/ type international international
voice translation-rule 200
rule 1 /^/ /0/ type unknown unknown
rule 2 /^/ /00/ type national national
rule 3 /^/ /000/ type international international
voice translation-profile ISDN-in
translate calling 200
translate called 10
voice translation-profile ISDN-out
translate calling 30
translate called 20
voice translation-profile SIP-in
translate calling 130
translate called 110
voice translation-profile SIP-out
translate called 120
voice-card 0
Debug ISDN Q931:
RO-Ker-01-AC-UGK#debug isdn q931
debug isdn q931 is ON.
RO-Ker-01-AC-UGK#
000108: Aug 30 11:45:36.790 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 89xxxx0
000109: Aug 30 11:45:36.794 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 017xxxxx061
RO-Ker-01-AC-UGK#
000110: Aug 30 11:45:42.794 MEZ: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000111: Aug 30 11:45:42.798 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 4405593DF1BE11E18007EA9D9BCFC2D0, SetupTime 11:45:42.798 MEZ Thu Aug 30 2012, PeerAddress 017xxxxxx61, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 11:45:42.798 MEZ Thu Aug 30 2012, DisconnectTime 11:45:42.798 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000112: Aug 30 11:45:42.798 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 11:45:36.774,cgn:89xxxx0,cdn:017xxxxxx61,frs:0,fid:2,fcid:4405593DF1BE11E18007EA9D9BCFC2D0,legID:2E,bguid:4405593DF1BE11E18007EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000113: Aug 30 11:45:47.666 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 4405593DF1BE11E18007EA9D9BCFC2D0, SetupTime 11:45:28.526 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 11:45:47.666 MEZ Thu Aug 30 2012, DisconnectTime 11:45:47.666 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000114: Aug 30 11:45:47.666 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 11:45:28.526,cgn:1001,cdn:,frs:0,fid:1,fcid:4405593DF1BE11E18007EA9D9BCFC2D0,legID:2D,bguid:4405593DF1BE11E18007EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
Anyone an idea ? What is my problem ?
THX @ll
Solved! Go to Solution.
08-30-2012 04:14 AM
Your ISDN BRI layer 2 status is down.
ISDN BRI0/2/0 interface
dsl 8, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
Have you configured the correct switch type? Is this the correct switch type your provider supports?
Can you post a debug isdn q921.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-30-2012 03:15 AM
can you send the full debug isdn q931 details.
08-30-2012 03:22 AM
Here is the ISDN q931 details:
RO-Ker-01-AC-UGK#debug isdn q931 detail
debug isdn q931 detail is ON.
RO-Ker-01-AC-UGK#
RO-Ker-01-AC-UGK#
000115: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931d: Default type/plan 0x0 0x0 sw-type 1 Calling number 89xxxx0 isdn_map 0 mask 0x3042
000116: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931d: Calling plan/type unspecified in call_decode, so ignored.
000117: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931d: No call_decode, isdn default set
000118: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 89xxxx0; Oct3a 0x0
000119: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931d: Default type/plan 0x0 0x0 sw-type 1 Called number 017xxxxxx061 isdn_map 0 mask 0x3042
000120: Aug 30 12:17:59.286 MEZ: ISDN BR0/2/0 Q931d: Called plan/type unspecified in call_decode, so ignored.
000121: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: No call_decode, isdn default set
000122: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 017xxxxxx061
000123: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_Go: source 0x0400, ces 1, event 0x0080, call id 0x8004, int id 0x0
000124: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_Go: event 0x80 cr_len 1 cr 0
000125: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_GetNew_NLCB: call_id 0x8004 int_id 0, ces 1
000126: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_Go: call_id 0x8004 cr 0x0 state 26 event 0x80 ces 1
000127: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_ProcessEvent: callref = 0x0000 CC_SETUP_REQ:U98_SetupReq(nlcb)
000128: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_EnQueue: Event not yet processed, but queued - state 1A event 80
000129: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: L3_MailPkt: Request 0x0200 to callref/callid 0x8004/0000 on CES 1
000130: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: srl_send_l3_pak:
source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_EST_REQ 0x0200
priv_len = 4 int_id = 0x4A8A9B98 datasize = 16
000131: Aug 30 12:17:59.290 MEZ: ISDN BR0/2/0 Q931d: data =
000132: Aug 30 12:17:59.290 MEZ: 4A8A9B98000003000200040000010400
000133: Aug 30 12:17:59.290 MEZ:
000134: Aug 30 12:17:59.294 MEZ: ISDN BR0/2/0 Q931d: L3_state_change: callref 0x0000 old DL_IDLE_STATE, new ESTABLISH_WAIT
000135: Aug 30 12:17:59.294 MEZ: ISDN BR0/2/0 Q931d: L3IF_rx_L2_pak: received data
000136: Aug 30 12:17:59.294 MEZ: 0001
000137: Aug 30 12:17:59.294 MEZ: ISDN BR0/2/0 Q931d: srl_send_l3_pak:
source_id = ME 0x0700, dest_id = Q.921 0x0000, prim = MDL_UI_DATA_REQ 0x0650
priv_len = 4 int_id = 0x4A8A9B98 datasize = 21
000138: Aug 30 12:17:59.294 MEZ: ISDN BR0/2/0 Q931d: data =
RO-Ker-01-AC-UGK#
000139: Aug 30 12:17:59.294 MEZ: 4A8A9B9800000700065004003F000400
000140: Aug 30 12:17:59.294 MEZ: 0FAF8C01FF
RO-Ker-01-AC-UGK#
000141: Aug 30 12:18:01.294 MEZ: ISDN LIFd: l3_timer: timer Expiry (0x4FEFC6DC), timer_type (0x1710)
000142: Aug 30 12:18:01.294 MEZ: ISDN LIFd: l3_timer: Post primitive to ME MailBox 4786D60C:
000143: Aug 30 12:18:01.294 MEZ: ISDN BR0/2/0 Q931d: srl_send_l3_pak:
000144: Aug 30 12:18:01.294 MEZ: ISDN BR0/2/0 Q931d: data =
000145: Aug 30 12:18:01.294 MEZ: 4A8A9B9800000700065004003F000400
000146: Aug 30 12:18:01.294 MEZ: 0FA84D01FF
RO-Ker-01-AC-UGK#
000147: Aug 30 12:18:03.294 MEZ: ISDN LIFd: l3_timer: timer Expiry (0x4FEFC6DC), timer_type (0x1710)
000148: Aug 30 12:18:03.294 MEZ: ISDN LIFd: l3_timer: Post primitive to ME MailBox 4786D60C:
000149: Aug 30 12:18:03.294 MEZ: ISDN BR0/2/0 Q931d: srl_send_l3_pak:
000150: Aug 30 12:18:03.294 MEZ: ISDN BR0/2/0 Q931d: data =
000151: Aug 30 12:18:03.294 MEZ: 4A8A9B9800000700065004A43F000400
000152: Aug 30 12:18:03.294 MEZ: 0F2D1E01FF
RO-Ker-01-AC-UGK#
000153: Aug 30 12:18:05.294 MEZ: ISDN LIFd: l3_timer: timer Expiry (0x4FEFC6DC), timer_type (0x1710)
000154: Aug 30 12:18:05.294 MEZ: ISDN LIFd: l3_timer: Post primitive to ME MailBox 4786D60C:
000155: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: srl_send_l3_pak:
source_id = ME 0x0700, dest_id = Q.921 0x0000, prim = MDL_ERR_RESP 0x0692
priv_len = 4 int_id = 0x4A8A9B98 datasize = 17
000156: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: data =
000157: Aug 30 12:18:05.294 MEZ: 4A8A9B9800000700069204000001040A
000158: Aug 30 12:18:05.294 MEZ: 45
000159: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_Go: source 0x020A, ces 1, event 0x0211, call id 0x0000, int id 0x0
000160: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_Go: event 0x211 cr_len 0 cr 0
000161: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_GetUser_from_ces_callid: NLCB 4A8C0660 CallId 0x0000
000162: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_GetUser_from_ces_callid: NLCB 4A8C07A0 CallId 0x0000
000163: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_GetUser_from_ces_callid: NLCB 4A8C02A0 CallId 0x8004
000164: Aug 30 12:18:05.294 MEZ: ISDN BR0/2/0 Q931d: L3_GetUser_from_ces_callid: found 00000000
000165: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931d: L3_GetNew_NLCB: call_id 0xFFFF int_id 0, ces 1
000166: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931d: L3_Go: call_id 0xFFFF cr 0x0 state 26 event 0x211 ces 1
000167: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931d: L3_ProcessEvent: callref = 0x0000 DL_REL_IND:Ux_DLRelInd(nlcb)
000168: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931d: L3_StopT309()
000169: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931d: L3_MailPkt: Request 0x0311 to callref/callid 0xFFFF/0000 on CES 1
000170: Aug 30 12:18:05.298 MEZ: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000171: Aug 30 12:18:05.302 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId CA1F4DB9F1C211E1800CEA9D9BCFC2D0, SetupTime 12:18:05.302 MEZ Thu Aug 30 2012, PeerAddress 017xxxxx061, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 12:18:05.302 MEZ Thu Aug 30 2012, DisconnectTime 12:18:05.302 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000172: Aug 30 12:18:05.302 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 12:17:59.270,cgn:89xxxx0,cdn:017xxxxx061,frs:0,fid:4,fcid:CA1F4DB9F1C211E1800CEA9D9BCFC2D0,legID:60,bguid:CA1F4DB9F1C211E1800CEA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000173: Aug 30 12:18:12.222 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId CA1F4DB9F1C211E1800CEA9D9BCFC2D0, SetupTime 12:17:51.492 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 12:18:12.222 MEZ Thu Aug 30 2012, DisconnectTime 12:18:12.222 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000174: Aug 30 12:18:12.222 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 12:17:51.490,cgn:1001,cdn:,frs:0,fid:3,fcid:CA1F4DB9F1C211E1800CEA9D9BCFC2D0,legID:5F,bguid:CA1F4DB9F1C211E1800CEA9D9BCFC2D0
RO-Ker-01-AC-UGK#
08-30-2012 03:44 AM
Can you use this command to check the status of your isdn. please post the output
sh isdn status
Do another test call and send me "debug isdn q931" without the detail. I cant see the call setup in the previous log
08-30-2012 04:03 AM
show ISDN status:
RO-Ker-01-AC-UGK#sh isdn status
Global ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
ISDN BRI0/2/1 interface
dsl 9, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 9 CCBs = 0
Total Allocated ISDN CCBs = 0
RO-Ker-01-AC-UGK#
ISDN Q931 Debug:
Typing the numer and press "#"
RO-Ker-01-AC-UGK#
000175: Aug 30 12:48:35.166 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 89xxxx0
000176: Aug 30 12:48:35.170 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 17xxxxx061
RO-Ker-01-AC-UGK#
"Unkown Number" (in Display)
000177: Aug 30 12:48:41.170 MEZ: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000178: Aug 30 12:48:41.174 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 105202DDF1C711E18011EA9D9BCFC2D0, SetupTime 12:48:41.174 MEZ Thu Aug 30 2012, PeerAddress 17630314061, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 12:48:41.174 MEZ Thu Aug 30 2012, DisconnectTime 12:48:41.174 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000179: Aug 30 12:48:41.178 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 12:48:35.150,cgn:89xxxx00,cdn:176xxxxx1,frs:0,fid:6,fcid:105202DDF1C711E18011EA9D9BCFC2D0,legID:8E,bguid:105202DDF1C711E18011EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
Hang UP:
000180: Aug 30 12:48:48.378 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 105202DDF1C711E18011EA9D9BCFC2D0, SetupTime 12:48:27.258 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 12:48:48.378 MEZ Thu Aug 30 2012, DisconnectTime 12:48:48.378 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000181: Aug 30 12:48:48.382 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 12:48:27.250,cgn:1001,cdn:,frs:0,fid:5,fcid:105202DDF1C711E18011EA9D9BCFC2D0,legID:8D,bguid:105202DDF1C711E18011EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
That is all i see.
08-30-2012 04:14 AM
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
08-30-2012 04:46 AM
I think that that is correct:
basic-net3
NET3 switch type for UK, Europe, Asia, and Australia
because the layer 2 Problem... it schould be normal its only active by call.
Re: Cisco 2811 CME 8.6 ISDN /// VIC2-2BRI NT/TE
Mitchell, as discussed so many times in similar thread. that is normal with BRI.
CO switch removes power to the circuit, and that state is normal.
The router is supposed to be able to re-activate layer 3 when placing a call. This can be observed with "debug bri".
Debug ISDN Q921:
000196: Aug 30 13:30:43.641 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
RO-Ker-01-AC-UGK#
000197: Aug 30 13:30:53.641 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
RO-Ker-01-AC-UGK#
000198: Aug 30 13:30:54.957 MEZ: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=21653 ai=127
RO-Ker-01-AC-UGK#
000199: Aug 30 13:30:56.957 MEZ: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=40422 ai=127
RO-Ker-01-AC-UGK#
000200: Aug 30 13:30:58.957 MEZ: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=31815 ai=127
RO-Ker-01-AC-UGK#
000201: Aug 30 13:31:00.961 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId FA5407CCF1CC11E1801BEA9D9BCFC2D0, SetupTime 13:31:00.961 MEZ Thu Aug 30 2012, PeerAddress 017xxxxx61, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 13:31:00.961 MEZ Thu Aug 30 2012, DisconnectTime 13:31:00.961 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000202: Aug 30 13:31:00.961 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 13:30:54.937,cgn:89xxxx00,cdn:017xxxxx61,frs:0,fid:10,fcid:FA5407CCF1CC11E1801BEA9D9BCFC2D0,legID:CF,bguid:FA5407CCF1CC11E1801BEA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000203: Aug 30 13:31:03.681 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
000204: Aug 30 13:31:03.689 MEZ: ISDN BR0/2/0 Q921: User RX <- RRf sapi=0 tei=77 nr=1
RO-Ker-01-AC-UGK#
000205: Aug 30 13:31:13.641 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
RO-Ker-01-AC-UGK#
000206: Aug 30 13:31:20.253 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId FA5407CCF1CC11E1801BEA9D9BCFC2D0, SetupTime 13:30:47.333 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 13:31:20.253 MEZ Thu Aug 30 2012, DisconnectTime 13:31:20.253 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000207: Aug 30 13:31:20.253 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 13:30:47.333,cgn:1001,cdn:,frs:0,fid:9,fcid:FA5407CCF1CC11E1801BEA9D9BCFC2D0,legID:CE,bguid:FA5407CCF1CC11E1801BEA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000208: Aug 30 13:31:23.641 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
RO-Ker-01-AC-UGK#
000209: Aug 30 13:31:33.641 MEZ: ISDN BR0/2/0 Q921: User RX <- RRp sapi=0 tei=77 nr=1
debug bri:
RO-Ker-01-AC-UGK# debug bri
Basic Rate network interface debugging is on
RO-Ker-01-AC-UGK#
RO-Ker-01-AC-UGK#
000210: Aug 30 13:45:00.181 MEZ: dchan tx start
000211: Aug 30 13:45:00.189 MEZ: dchan tx intr
RO-Ker-01-AC-UGK#
000212: Aug 30 13:45:02.181 MEZ: dchan tx start
000213: Aug 30 13:45:02.185 MEZ: dchan tx intr
RO-Ker-01-AC-UGK#
000214: Aug 30 13:45:04.181 MEZ: dchan tx start
000215: Aug 30 13:45:04.185 MEZ: dchan tx intr
RO-Ker-01-AC-UGK#
000216: Aug 30 13:45:06.185 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId F1335F2DF1CE11E18020EA9D9BCFC2D0, SetupTime 13:45:06.185 MEZ Thu Aug 30 2012, PeerAddress 01xxxxxx61, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 13:45:06.185 MEZ Thu Aug 30 2012, DisconnectTime 13:45:06.185 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000217: Aug 30 13:45:06.185 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 13:45:00.165,cgn:89xxxx0,cdn:017xxxxx61,frs:0,fid:12,fcid:F1335F2DF1CE11E18020EA9D9BCFC2D0,legID:E7,bguid:F1335F2DF1CE11E18020EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000218: Aug 30 13:45:16.941 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId F1335F2DF1CE11E18020EA9D9BCFC2D0, SetupTime 13:44:51.011 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 13:45:16.941 MEZ Thu Aug 30 2012, DisconnectTime 13:45:16.941 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000219: Aug 30 13:45:16.945 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 13:44:51.013,cgn:1001,cdn:,frs:0,fid:11,fcid:F1335F2DF1CE11E18020EA9D9BCFC2D0,legID:E6,bguid:F1335F2DF1CE11E18020EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
08-31-2012 04:54 AM
No one any idea ?
09-02-2012 10:29 AM
Please send "debug isdn q931" only. No other debugs or output should be included.
09-04-2012 01:36 AM
RO-Ker-01-AC-UGK#un all
All possible debugging has been turned off
RO-Ker-01-AC-UGK#
RO-Ker-01-AC-UGK#term mon
000500: Sep 4 10:33:35.847 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 894xxx09
000501: Sep 4 10:33:35.851 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 017xxxxx061
000502: Sep 4 10:33:41.851 MEZ: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000503: Sep 4 10:33:41.855 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId BB78D69F5A211E180BEEA9D9BCFC2D0, SetupTime 10:33:41.855 MEZ Tue Sep 4 2012, PeerAddress 0176xxxxx061, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 10:33:41.855 MEZ Tue Sep 4 2012, DisconnectTime 10:33:41.855 MEZ Tue Sep 4 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
000504: Sep 4 10:33:41.855 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:09/04/2012 10:33:35.827,cgn:89xxx00,cdn:0176xxxx4061,frs:0,fid:49,fcid:BB78D69F5A211E180BEEA9D9BCFC2D0,legID:2906,bguid:0BB78D69F5A211E180BEEA9D9BCFC2D0
000505: Sep 4 10:33:49.967 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId BB78D69F5A211E180BEEA9D9BCFC2D0, SetupTime 10:33:32.797 MEZ Tue Sep 4 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29 , DisconnectText temporary failure (41), ConnectTime 10:33:49.967 MEZ Tue Sep 4 2012, DisconnectTime 10:33:49.967 MEZ Tue Sep 4 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
000506: Sep 4 10:33:49.967 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:09/04/2012 10:33:32.799,cgn:1001,cdn:,frs:0,fid:48,fcid:BB78D69F5A211E180BEEA9D9BCFC2D0,legID:2905,bguid:0BB78D69F5A211E180BEEA9D9BCFC2D0
09-03-2012 12:16 PM
Hi Jan,
can you share the output of debug voip ccapi inout & debug isdn q931.
(Kindly share the whole output with the outgoing - setup msg)
Kevin
09-03-2012 02:24 PM
yes i can tomorrow... sorry for the late answer. i left for a short trip
09-04-2012 01:42 AM
09-04-2012 01:49 AM
Some other idea... what is if the ISDN Port is OK but the Call routing is wrong ? Means, is there a failure in my tranlation rules ?
tonight i called intern the number 1002 an it has the same efect. "unknown Number" because the telefon was not reachable.
09-04-2012 02:18 AM
Jan,
Looking at the trace, It doesnt look like its your translation rule. It looks like you have a problem with the ISDN.
Here is the detail of the trace..
1. Call setup request come in to the gtateway fro extension 1001
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
2. The gateway request a call setup to the ISDN via dial-peer 10.
Here the calling number is xlated from 1001 to 89491700
Guid=965F284C-F5A2-11E1-80C3-EA9D9BCFC2D0, Outgoing Dial-peer=10
000584: Sep 4 10:37:28.479 MEZ: //10511/965F284C80C3/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=89491700
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=017630314061
3. Immediately after the callsetup request is sent to the ISDN by the gateway, the call drops
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
000593: Sep 4 10:37:28.483 MEZ: //10512/965F284C80C3/CCAPI/ccCallSetContext:
Context=0x4FF45224
000594: Sep 4 10:37:28.483 MEZ: //10511/965F284C80C3/CCAPI/ccSaveDialpeerTag:
RO-Ker-01-AC-UGK#Outgoing Dial-peer=10
RO-Ker-01-AC-UGK#
000595: Sep 4 10:37:34.507 MEZ: //10512/965F284C80C3/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x4C0EF0E8, Call Id=10512 SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Context=0x4FF45224
RO-Ker-01-AC-UGK#
This shows that there is a problem with the ISDN side.
