Cisco CCM 4.1(3)ES111 -> Upgrade 4.1(3)SR7 CDR/Translation Pattern Question
at present we are running 4.1(3) ES111 due some Nice Voice Recording issues.
We are upgrading to 4.1(3)SR7 next weekend as these fixes have not been added to SR6.
We are using Proteus as a call logging solution and at present on ES111 the CDR Data does not output the originating number that has been dialled when using Translation patterns.
We only see a Trunk to Trunk connection if calls get translated externally but we have no way to identify or cost any of these kind of calls.
Is there more details within 4.1(3)SR7?
Steffen
1 REPLY
Re: Cisco CCM 4.1(3)ES111 -> Upgrade 4.1(3)SR7 CDR/Translation P
SRs are based on ES versions, look at the readme for the SR7 for more info of what has been fixed and what changes will be applied to the system
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
95
