Community Member
CISCO CCM 5.1.2 & CUPS Server
The connection between CCM & CUPS is working. The troubleshoouting tool from the CUPs did not show any failure.
But i cant see the status from the telephone on the presence client. I can only see the status if the user i logged on or the user has not used his computer for some time.
If i pick up the phone, the window in the CUPC opens but i cant se the status in the CUPC.
I can dial from the CUPC, this also works fine.
I can add other users to my profile, but i cant see their phone status on my CUPC.
Community Member
Re: CISCO CCM 5.1.2 & CUPS Server
Hi, anyone have feedback on this issue? I'm running into the exact same thing?
Any suggestions would also be appreciated
Community Member
There are no changes it is still the same problem on my system
Regards Thomas
Community Member
You need to enter something (cisco for example) in the "Associated PC Digest Credentials" parameter of the End User CCM configuration.
Strange but it worked for me.
kr
jp
Community Member
I also just saw that, thanks for the response - weird, I used 12345 and the whole thing just came to life. Is there any documentation on the "why" question?
Community Member
I think I have the same problem.
Do you just have to enter something on the End User logged into the Communicator or is it every user?
227
