Cisco CCM 5.x Subscriber DB is not sync with Publisher
CCM version is as below,
System version: 5.1.1.3000-5
Subscriber DB is not sync with Publisher. Any Change in phone configuration on Publisher is not reflecting on Subscriber and vice versa.
I have restarted Subscriber, still problem is same.
on Publisher, i run "utils dbreplication repair all" command, still problem is same.
Pls. suggest.
1 REPLY
Re: Cisco CCM 5.x Subscriber DB is not sync with Publisher
Hi Rajesh,
You can follow this document to diagnose the status yourself. However many of the commands and troubleshooting approaches listed were not present in 5.1(1) so a TAC case would be advisable if it does not help you.
As a side node you may also want to consider upgrading this cluster to 5.1(3) as some point. As per software compatibility, you can upgrade directly to 5.1(3f)
427
