Cisco CCM 6 disconnect the call after 5 minutes
Any idea on how to configure a extension number in CUCM 6 to disconnect the call after 5 minutes?
Re: Cisco CCM 6 disconnect the call after 5 minutes
That's not possible in CUCM, we have a call duration parameter but it's clusterwide
If this is for outbound calls and you use H323 you could look into TCL scripting
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Do you have any example? Im not a partner, Im end user.
205
