Cisco CCM on non-MCS for LAB
How i can install cisco CCM on non-MCS equipment for lab.
Hall of Fame Super Red
Re: Cisco CCM on non-MCS for LAB
Silver
I have had the benefit of completing this task using the following exact steps:
1) Install W2k Advanced Server with:
Accessories and Utilities,
Indexing Service,
IIS,
Management and Monitoring tools
2) Assign an IP address, DNS and default gateway (can not be DHCP)
3) Install IE6 Service Pack 1 (ie6setup.exe)
4) Install W2k SP4 (W2KSP4_EN.EXE) DO NOT INSTALL ANY ADDITIONAL UPDATES
5) Install the old MS Java (msjavx86.exe) I'm not positive this is necessary but...
6) Modify the registry
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems\Model]
?Hardware?=?MCS7835?
?Memory?=?1024?
?Speed?=?733?
[HKEY_LOCAL_MACHINE\SOFTWARE\Spirian\System Info\OS Image]
?Version?=?2000.2.5?
7) Give "everyone" read rights to the \winnt\registration folder
8) Install win-OS-upgrade-K9.2000-2-7.exe (The server will reboot several times, I thought it was only twice but maybe it was three)
Install win-OS-upgrade-K9.2000-2-7sr7.exe (It rebooted when it was complete)
9) Copy "shutdown.exe" from c:\program files\cisco\updates\2002.7sr7 to c:\utils
10) Double check in services to make sure IIS is running.
11) Start - Programs - Cisco CallManager 4.1 - Cisco Service Configuration. Turn on the rest of the services that you need and go.
this worked for me first time - just make sure you've minimum of 1GB RAM.
hth,
Ajaz
Thanks Ajaz
So that means i do not need..VM ware or virtual machine...
Silver
that's right!
hth,
Ajaz
pls remamber to rate any useful post.
hello Ajaz
sorry to come back so late and not to rate it..one last questions..i could't arrange windows 2000 advanced server..any chance i could install it on windows 2003 enterprise server..and which version of CM i can install..
thanks..
Silver
No. It must be Windows 2000 Server or Advanced Server.
Ajaz
138
