Cisco CCM services restarting itself
I just patched my CCM cluster 4.1(3)srb with ES122. But, on one of the server, the CCM service keeps on restarting itself and filling the logs. We only use this server for CTI application such as ARC.
Any thoughts pls, its urgent.
thanks in advance.
Moh
Re: Cisco CCM services restarting itself
Could you please paste the exact error that you are getting?
Did you install the ES122 on all the servers in the cluster?
//J
Green
You need to check the following:
http://cco/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d2577.shtml
If it is urgent contact TAC
I get the following error in the trace file.
12/10/2007 08:32:03.776 CCM|Callmanager is starting.|<:PUBLISHER-CLUSTER><:10.10.10.10>
12/10/2007 08:32:18.339 CCM|EnvProcessUdpPort - EnvProcessUdpHandler thread started|<:PUBLISHER-CLUSTER><:10.10.10.10>
12/10/2007 08:32:18.354 CCM|TLS Listener is active for 10.10.10.10:2446|<:10.10.10.10><:6><:><:>
12/10/2007 08:32:20.042 CCM|dBProcs - ERROR readStationRegistrationProfile, ccm = [10.10.10.10]|<:PUBLISHER-CLUSTER><:10.10.10.10>
12/10/2007 08:32:20.058 CCM|Db - DBL exception when loading StationRegistrationProfile table - restart CCM|<:PUBLISHER-CLUSTER><:10.10.10.10><:6><:><:>
thanks
Moh
114
