Cisco CCME ephone-hunt
Hi guys,
I have problem with ephone-hunt I want to finish call of hunt group on external mobile number,
but I can't put for final number external mobile number How I can solve this problem?
Configuration of hunt group:
ephone-hunt 1 sequential
 pilot 101
 list 130, 131, 113, 135, 121
 final ------>external mobile number
 timeout 10, 5, 5, 5, 5
 statistics collect
Tomislav
23 Replies 23
Hello!
U have different Invite messages.
Good call:
From: "9262483188"<sip:89262483188@sip.wiland.ru;user=phone>
Bad call:
From: "9262999777"<sip:89262999777@sip.provider;user=phone>
What are this numbers?
U call from outside...try to call from IP-phone to your hunt-pilot...it should work..
Kirill
Hi Kirill,
This second file is ok in the first i did changes
and 483188 replace 999777 I wanted to make more secure but I saw how you
didn't understand and share this original from GW.
​For me is interesting if calls from outside can be redirected to external mobile because this is the case when one operator is alone at night or for a weekend.
I will try to test and call from inside this pilot number but do you know how I can solve my problem.
Thanks in advance!
Tomislav
You can try to modify SIP-header using voice class sip-profiles.
Another way is configuration on dial-peer:
clid network number <number>
Kirill
Hi Kirill,
I didn't understand totally what is the problem, please can you explain me little bit.
I changed phone numbers manually in the log after capturing just for security and after that provided you with orginal.
Tomislav
Hi All,
Kirill thank you for your help, After more debugging I found what is the problem :)
I needed to change two things in sip INVITE msg Diversion and From
Please find configuration:
voice class sip-profiles 1
 request INVITE sip-header Diversion modify "<sip:(.*)@(.*>)" "<sip:sip:0123456@10.3.1.1>"
 request INVITE sip-header From modify "<sip:(.*)@(.*>)" "<sip:0123456@sip.wiland.ru>"
Can you post your telephony-service config? You may need to add the following:
transfer-pattern .T
transfer-system full-blind
Yosh
HTH Regards, Yosh
Hi Yosh,
Please look at:
telephony-service
 sdspfarm units 2
 sdspfarm tag 1 cfb001f6cd3c5a0
 sdspfarm tag 2 xcode9927
 conference hardware
 conference transfer-pattern
 max-ephones 150
 max-dn 450
 ip source-address 172.16.11.1 port 2000
 max-redirect 13
 service local-directory authenticate
 cnf-file location flash:
 cnf-file perphone
 user-locale RU
 network-locale RU
 network-locale 1 RU
 network-locale 2 RU
 network-locale 3 RU
 network-locale 4 RU
 load 7914 S00105000400
 load 7911 SCCP11.9-0-3S
 load 7960-7940 P00308010200
 load 7941 SCCP41.8-5-3S
 load 7961 SCCP41.8-5-3S
 time-zone 32
 time-format 24
 date-format dd-mm-yy
 max-conferences 6 gain 3
 call-forward pattern .T
 moh "music-on-hold.au"
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
BR
Tomislav
Hi Yosh,
I tried how you said, but nothing look at conf below:
telephony-service
 sdspfarm units 2
 conference hardware
 max-ephones 150
 max-dn 450
 max-redirect 13
 cnf-file perphone
 user-locale RU
 network-locale RU
 network-locale 1 RU
 network-locale 2 RU
 network-locale 3 RU
 network-locale 4 RU
 time-zone 32
 time-format 24
 dn-webedit
 time-webedit
 transfer-pattern .T
Case1
voice hunt-group 1 sequential
 final 8xxxxxxxx
 list 130,131,113,135,121
 timeout 10
 pilot 101
Case 2
 list 130,131,113,135,121,8xxxxxxxx
 timeout 10
 pilot 101
Case3
 final 126
 timeout 10
 pilot 101
ephone-dn  41  dual-line
 number 126
 call-forward all 8xxxxxxxxxx
I would verify your dialing prefix like Krill mentioned (+5) and also you can consider having a place holder DN that is set to forward all calls to the mobile number.
ephone-dn 99
number "dummy number"
call-forward all "prefix and mobile number"
 final "dummy number"
 timeout 10
 pilot 101
Yosh
HTH Regards, Yosh
