Community Member
Cisco CCX
Im new with CCX and I can see that in the list of servers the status for the servers I have are in "PARTIAL SERVICE ".
Any idea what I can check? or this is normal?
HiPerform JTAPi client and
Perform JTAPi client and JTAPI Dat Resync operation.
It’s because any of the Service in the server is not IN_Sevice
Under the "Cisco Unified CCX Administration Control Center" Check if there is any service which is not IN_Service state.
Refer Below link for more detail.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/troubleshooting/guide/uccx70srvtrbl.pdf
Venkatesh
Community Member
Hello venperum, I cand find
Hello venperum,
Unified CM Telephony Subsystem  --> PARTIAL SERVICE
VOIP Monitor Subsystem --> PARTIAL SERVICE
Thanks.
Hi, did you Perform JTAPi
did you Perform JTAPi client and JTAPI Dat Resync operation. If not please do that and refer below thread.
https://supportforums.cisco.com/document/134556/cm-telephony-subsystem-partial-service-or-oos
Venkatesh
85
